RX8 ECU Pinout Diagram
Old Mar 8, 2012 | 08:05 AM
doc.tarzan's Avatar
Question RX8 ECU Pinout Diagram
Please help me find the pinout diagram of rx8 ecu , six speed 2003 .
Would be REALLY Appreciated.Thanks
Old Mar 8, 2012 | 08:06 AM
bse50's Avatar
#50
the service\electrical manual has it.
So... Rtfm!
Old Mar 8, 2012 | 08:25 AM
doc.tarzan's Avatar
thanks .. but i cannot find pinout diagram to tap in speedo and rpm
Old Mar 8, 2012 | 08:30 AM
doc.tarzan's Avatar
need to know which pins are what on the ecu connector ... hope you understand what i mean
Old Mar 8, 2012 | 12:15 PM
oltmann's Avatar
Speed and RPM are transmitted over CAN bus.
http://blog.hiroaki.jp/2010/04/000469.html
Old Mar 8, 2012 | 12:45 PM
StealthTL's Avatar
Metatron
No pins for rpm or speed.
If you send me an email I can send a pin out diagram, but you won't like it.....
Old Mar 9, 2012 | 02:23 AM
doc.tarzan's Avatar
^^ thanks ... email sent
Old Mar 9, 2012 | 11:00 AM
all of that info is in the Technical Forum stickies
Old Sep 23, 2012 | 12:51 AM
winstone's Avatar
In need of help urgentlu
I need a diagram that shows the ECU pinout for the Mazda Rx8, 2005 model, 5 speed.
I also need to know the color code for wire going to the injectors for the said car. can u help me or put on some one to me. I am desperate
Old Sep 23, 2012 | 03:45 AM
bse50's Avatar
#50
It's going to be difficult. Start with the 4speed AT ecu and a MT6 speed one and see what's different in your case.
5 speed cars were only sold for in a limited market, it's hard to find manuals for them.
Old Sep 23, 2012 | 09:00 PM
StealthTL's Avatar
Metatron
Diagram sent.
Old Sep 23, 2012 | 09:16 PM
ShellDude's Avatar
weeeeeeeeee
5 speed is a 4 port if memory serves correctly. The pinout is likely the same as the USDM 4 port.
4 looms instead of 5 is my bet.
Old Sep 24, 2012 | 07:36 PM
StealthTL's Avatar
Metatron
Sent and re-sent.....
Old Mar 12, 2014 | 09:47 AM
Rx8 greece's Avatar
im putting 1jz to rx8 with the jz transmition i will put the 2 ecus can you send me please the diagrams?
Old Jul 7, 2014 | 03:33 PM
logalinipoo's Avatar
Driving my unreliable rx8
Old Jul 8, 2014 | 05:46 AM
You will do yourself and everyone else a favor to instead teach these people how to search properly
Old Jul 8, 2014 | 01:19 PM
AAaF's Avatar
With all respect, disagreed.
Without checking this specific case, what one find easily, another struggle with. I've been around in this forum for almost 5 years, and still I hesitate to post questions(even though people have been merciful and I have gotten good answers). Thats not good, and does not benefit forum, its a good chance that we miss good questions this way.
In forums for audio, where I'm active, and a bit more of a resource, its complete opposite of here. We keep a friendly tone, and repeat truths many time and if someone comes with a comment, "use the freaking search function", he get told to simply not read it if he has a problem with it. This keep the common knowledge level, and innovation high.
Repeating a fact should not be a problem, it only increase the chance of next guy finding out by himself.
Old Jul 8, 2014 | 03:59 PM
I push people to search and try not to respond if i do think they have. I largely agree that people do not search enough including me. The only reason i posted that here is it is a easy diagram for the everyday things people might be interested in. I have never seen that and I've been through over 3400 threads. I also realize that I've searched for days reading 50-100 threads then asked and someone produced the answer quickly because they know the key words to search.
Old Jul 8, 2014 | 05:12 PM
never mind that it's linked on post #2
Old Aug 27, 2014 | 05:36 AM
Rx8 greece's Avatar
thanks a lot everything work perfect and its the first street rx8 with 1jz in greece and cyprus!!!
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
F51
Aug 2, 2021 04:07 AM
rotorocks
47
May 11, 2016 03:23 PM
RX7.9
Jul 20, 2015 12:01 PM
