Mazda's "Gram Strategy" Leaves No Bolt Untouched
Old Mar 7, 2012 | 12:47 PM
ASH8's Avatar
Super Moderator
http://www.popularmechanics.com/cars...eight-strategy
Mazda was so serious about weight loss when they designed their new CX-5 Skyactiv that they not only employed the usual trim-down techniques (more high tensile steel, less unecessary bulk), they employed a "gram strategy" approach that literally leaves no bolt untouched.
For example, look at an old seat bolt (right) and a new one (left.) The move to a reverse Torx head allows the lighter version to be screwed or unscrewed using a standard 10mm socket wrench. More crucially, it saves 8 grams per unit. That may not sound like a lot of mass, but minute alterations like that helps the CX-5 ditch anywhere from 288 lbs to 575 lbs compared to the outgoing CX-7, which has essentially the same interior volume.
Pretty sweet, huh?
Old Mar 7, 2012 | 01:28 PM
dynamho's Avatar
Cool.
Why do they say it's a reverse Torx head to confound things?
It looks like a standard bolt that's been carved out.
Old Mar 7, 2012 | 01:30 PM
paimon.soror's Avatar
because the shape is literally the inverse of a torx head....?
Old Mar 7, 2012 | 02:53 PM
dynamho's Avatar
I don't have issue with the description, paimon.
To me, they made it sound as if there really is something called a reverse Torx head (as in pre-existing), for which there's a specialty tool for. This bolt works with a standard socket.
Old Mar 7, 2012 | 02:56 PM
dozer's Avatar
on his 3rd rx8
ahhhh even the little things count. nice yob mazda
PS buttsecks.
Old Mar 7, 2012 | 02:58 PM
Oh lol, yea but i suppose if you are using it in an application where a significant amount of torque is required, you would end up rounding off the points if you were using a standard socket.
Old Mar 7, 2012 | 03:56 PM
dynamho's Avatar
True.
In the original post Ash8 made, one of the comments (the only comment I think) in the link piqued my interest, but I'm having trouble getting clarity on what this guy means. It sounds like some sort of stress failure, but I can't picture da Fail.
"Sterling Calhoun · Memphis, Tennessee
Maybe they should talk to Suzuki and take some lessons from the GSXR series sportbikes. From the way this trend is going, there will be a hole right through the middle of the bolt next year (just like the brake caliper bolts on my bike)."
Old Mar 7, 2012 | 04:52 PM
tjbourgoyne's Avatar
tjb
Is this done for the entire car or just specific bolts?
56 bolts at 8 grams (roughly) = 1 lb. It would take a lot of bolts to make it worth while.
Old Mar 7, 2012 | 05:22 PM
godesshunter's Avatar
Voids warranties
There is. Its nothing new. Its actually very common in European cars. Has been for years. The use of a standard socket can easily round off the head making it very difficult to remove after. The proper tool for the job looks like this.
Try doing rear brakes on a Saab or Volvo without one of these that is impact rated and you will have a bad day.
Old Mar 7, 2012 | 05:49 PM
dynamho's Avatar
Oh OK. Thanks godesshunter. Never seen one before.
Looks like the more standard term for that is External Torx.
Good to know.
Old Mar 7, 2012 | 05:57 PM
Voids warranties
There is some fancy name for it. I forget what it is but most mechanics refer to it as "inverted torx"
Old Mar 7, 2012 | 06:20 PM
dynamho's Avatar
So does this mean, Mazda's doing what the Europeans have been doing all along? ;D
Old Mar 7, 2012 | 06:38 PM
Voids warranties
Possibly. But at least Mazda has reasoning behind it. I'm sure the euros did it just to be obnoxious.
Old Mar 7, 2012 | 07:40 PM
dynamho's Avatar
Old Mar 8, 2012 | 03:22 AM
ASH8's Avatar
Super Moderator
I call them a 'star' socket, but probably wrong..
airlive
Nov 4, 2016 12:15 PM
Silver_Excalibur
Aug 25, 2015 09:09 PM
MolsonB
Aug 8, 2015 01:24 AM
arjunmshah
Aug 6, 2015 10:56 AM
iverzc
Jul 17, 2015 10:28 PM
