Hymee Supercharger Owners
Old Mar 6, 2012 | 04:51 PM
WingleBeast's Avatar
HAVOC
Place to share and compile kits and mods. Trying to keep arguments, and pissing matches for those who aren't owners to a minimum.
Owners
1. SKC - Only other running kit at this time? -Bought from Revolver
2. Hoss - Uninstalled (for sale?)
3. WingleBeast - Bought from Arrowhead
4. Danny from Automotive Plus - uninstalled?
Past Owners
1. Hymee - The man, the myth, the legend
2. Revolver - Sold Car
3. Arrowhead - Never Installed
HAVOC
Reserved for Setup Photos
Old Mar 6, 2012 | 04:52 PM
HAVOC
Reserved for Dynos
Old Mar 6, 2012 | 08:01 PM
skc's Avatar
skc
rev it up
Hymee does not own a RX8 now. My car is the only one with the Hymee kit running. i purchased my kit off Revolver and was installed by Danny's workshop, Automotive Plus.
Danny has purchased two kits for his cars however, after his engine died due to tuning issues it has not been reinstalled.
This kit still has some flaws. The main problem seems to be with the bypass valve which will need a redesign. Danny, will be attending to this once he finds the time in his busy schedule. I am happy with my kit despite the minor problems.
There are other kits out there so we may hear from other owners over time.
My build thread has all the photos and progress details: https://www.rx8club.com/series-i-major-horsepower-upgrades-93/skc-supercharger-build-218874/
Old Mar 13, 2012 | 01:28 AM
hoss -05's Avatar
Lucky #33
Huh good to see this up..... but may be going a different route with FI now. My kit may be up for sale soon.
Old Mar 13, 2012 | 09:08 PM
HAVOC
haha, the Hymee kits are like ancient art. Only a few and they keep getting sold to new people.
Old Mar 14, 2012 | 12:59 PM
Chris's Avatar
Turbo Member
yeah and they are still in boxes never used
Old Mar 14, 2012 | 06:03 PM
skc's Avatar
skc
rev it up
Best option is to send the kits to Danny of Automotive plus so he can fix the defects and then it is good to install.
However, the bypass valve has not been fixed yet so you will have to wait until Danny has had a chance to address this issue. Once the bypass is sorted the idle issue should be resolved.
Old Mar 14, 2012 | 07:30 PM
HAVOC
did you try running without the spring? worth a shot
Old Mar 14, 2012 | 11:50 PM
Ancient art? Like a 1948 Tucker sedan maybe ...
Old Jul 24, 2017 | 09:16 PM
skc's Avatar
skc
rev it up
Thread revival: I sent my kit to Bullet cars in Queensland, Australia to get the system modified. the following items where changed:
Original bypass blocked off
new bypass added just before the intake plenum
Larger oil line added for engine oil lubrication
Machined for larger bolts
Machined for better slow of oil around gears
My new engine is in run in mode for the first 1000km and then the supercharger gets strapped on. Hopefully should be back on and running within a month.
Old Apr 25, 2018 | 09:23 AM
Fezz's Avatar
Did you get it up and running with the changes.
Old Apr 27, 2018 | 01:23 AM
skc's Avatar
skc
rev it up
Getting closer to installing the supercharger. I have been in touch with Brettus to help with the tune.
The next steps
1/ reinstall the remote oil filter
2/ purchase new injectors rather than reuse old ones
3/ block off the engine oil feed (plan to use gear oil instead)
4/ Install supercharger
5/ Tune
So it getting very close to installation time
Old Apr 28, 2018 | 08:49 PM
Fezz's Avatar
I can’t wait to see the setup and see the changes you made . I have followed the hymee superchargers for awhile and read the forums. But I finally joined the last week cause this year I might try to get hold of who still owns one of these to see if I can take it off their hands and put it to use .
Thanks for the update on your build skc.
Old May 20, 2018 | 10:06 PM
HAVOC
My kit is sitting oiled in a box in the garage. Let me know how the changes go!
Old May 21, 2018 | 09:37 PM
skc's Avatar
skc
rev it up
Getting close at step 4 now. Probably attempt install the supercharger tomorrow.
I have blocked off the engine oil feed so i will order some gear oil.
Mazdaedit installed with tactrix so I can get it tuned.
Old May 21, 2018 | 10:00 PM
skc's Avatar
skc
rev it up
What oil can I use? Will gear box oil work?
Old May 25, 2018 | 08:21 AM
skc's Avatar
skc
rev it up
How do I attach this part? I cannot find where it mounts to, any pictures available. I want to get my supercharger installed and running asap.
Old May 25, 2018 | 08:34 PM
rotarenvy's Avatar
it's the air conditioner belt pulley. look for two holes on your sc mounting plate over on the left (.au passenger side) of the engine
now that I have seen this
it looks like it uses this mounting stud.
Last edited by rotarenvy; May 25, 2018 at 08:42 PM. Reason: better understanding of the kit
Old May 25, 2018 | 09:33 PM
skc's Avatar
skc
rev it up
It has two bolts so I was thinking there would have been a mounting block perhaps?
Old May 25, 2018 | 10:37 PM
rotarenvy's Avatar
post a pic of the front mounting plate. after looking at the red mounting plate I still think there would be two holes on the bottom left of it for it to bolt on to.
doese look like it is missing a part to bolt to.
this pic below shows the origional mounting point is still available and there is nothing on the sc mounting plate in that area.
Old May 25, 2018 | 11:53 PM
skc's Avatar
skc
rev it up
Thanks for the picture.
I have an additional pulley could be for the a/c. I may have to use the modified pulley instead to the stock.
Old May 26, 2018 | 01:14 AM
skc's Avatar
skc
rev it up
Here is another photo
Old May 26, 2018 | 01:40 AM
skc's Avatar
skc
rev it up
I have the modified pulley. I have printed this photo and tonight I will try to see how I can get it attached
Old May 27, 2018 | 12:43 PM
HAVOC
SKC,
based off the photos above that is the AC belt idler. It sucks. I never figured out how to accurately tension it. But it does attach through those front cover bolts
