Trouble shooting stereo
Old Feb 26, 2012 | 12:41 AM
Wanny's Avatar
My wife's 09 RX8 with Bose system is not playing any sound.
For roughly a month the stereo was making loud random popping sounds until finally no sound will emitt.
I have not checked the fuses yet, I am working night shift and can't check until tomorrow, even if it was a fuse there is a different problem from the popping sound.
The car is no longer under warranty. Bought in July of 08... Dammit.
I am leaning towards a blown amp. If the amp in the truck was to blow can I expect no sound out of any of the speakers? Any way to really test this?
Mike
Old Feb 26, 2012 | 06:22 PM
Wanny's Avatar
Just checked the fuses and connections to the amp. Everything looked good. I plan to start hunting around for a used amp.
Has anyone else had this issue or experience and confirm its most likely the amp?
Old Feb 26, 2012 | 08:27 PM
xexok's Avatar
The only way to confirm it will be to replace it, or if you want you could remove it and test it with a volt meter.
I have 3 car amps sitting in my garage I have to do this to as well. It can be very very time consuming. You may get lucky and be able to spot a burnt part inside without further testing. http://www.ehow.com/how_7832227_fix-...amplifier.html I would ignore where they say to test it in the car, and maybe buy a nice 12v power supply, or rig up a computer power supply to give the amp power off the 12v rail/plug.
There is also some DIY posted around here about fixing the bose system, but that may not be your problem.
Old Mar 2, 2012 | 06:38 PM
Wanny's Avatar
Thanks for the tips. I pulled it out and inspected for any obvious issues and found none. I might take it took work and try and trouble shoot the board. I think I will need a fairly detailed schematic to figure anything out.
crimson809
Aug 14, 2016 10:03 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
RotaryMachineRx
Sep 29, 2015 10:26 PM
Tgiolitto100
Sep 29, 2015 10:52 AM
