I need to change my motor mounts. I heard they have Polyurethane ones?
Old Feb 19, 2012 | 11:42 AM
toke_'s Avatar
I have alot of vibration into the carriage so im assuming its the motor mounts. I heard theres polyurethane motor mounts which would be better quality. Where can i buy them?
Old Feb 19, 2012 | 11:49 AM
bse50's Avatar
#50
Megan racing sells polyurethane filled stock motor mounts.
However before spending money on them i'd just fill my set or have somebody else do it.
Where are you from?
Old Feb 19, 2012 | 12:47 PM
toke_'s Avatar
south florida
Old Feb 19, 2012 | 01:09 PM
bse50's Avatar
#50
Can't help you then, just buy a set of used motor mounts and fill them.
Old Feb 19, 2012 | 01:58 PM
toke_'s Avatar
can i use medium soft urethane(40a) instead of using hard. wouldnt it give me less vibration?
Old Feb 19, 2012 | 01:59 PM
bse50's Avatar
#50
yep
Old Feb 19, 2012 | 02:13 PM
toke_'s Avatar
so if using medium soft will give less vibration to the carriage then why do people use 80A hard?
Old Feb 19, 2012 | 02:21 PM
bse50's Avatar
#50
I personally use a 72A shore.
Performance wise harder mounts give faster throttle response and have some other advantages. I'd use a 60a shore instead of a 40 anyway.
Old Feb 19, 2012 | 02:33 PM
toke_'s Avatar
well my rx8 is auto trans so it probably wont make a difference performance wise between 40a and 60a
Old Mar 9, 2012 | 08:54 AM
lasb1230's Avatar
Hi I'm from Miami and I have the same problem with my rx8 AT getting some vibrations...Please Let me know if changing the mounts solved your problem...thanks
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Skyl3r
Dec 2, 2019 04:51 PM
drebbrnator
Dec 27, 2018 07:02 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
AussieGray
Jul 16, 2015 03:58 AM
