Compression Test Intrepretation Help Please
Old Feb 17, 2012 | 04:22 PM
CRX Millennium's Avatar
AA = Autox Anonymous
Compression Test Intepretation Help Please
Had compression test done today on '04 RX-8 MT, with 99xxx miles on the clock. The temp was in low 60s, with elevation at 324ft per http://veloroutes.org. Here are numbers:
front rotor: 6.7/6.5/6.7 @239rpm
rear rotor: 6.7/6.6/6.7 @238rpm
Tech mentioned that these are healthy-looking figures, with cars needing engine replacement typically reading in 4s when calling techline and needing decarb treatment in 5s. My car sometimes cranks longer than normal when hot, but otherwise felt ok (subjective thus why I paid to get it tested).
Please help with conversion to sea-level @ 250rpm, which I thought mine falls within replacement guideline absolute-number-wise. Thanks!
Old Feb 17, 2012 | 04:27 PM
Those are out of spec numbers according to my Android compression test app.
And according to this:
http://www.flickr.com/photos/9krpmrx8/4497702781/
Old Feb 17, 2012 | 04:59 PM
Interesting graph you got, since it looks different than than sticky copy: http://www.twistedrotors.com/images/..._Comp_Test.jpg
I downloaded the Android RX-8 Compression Calculator mentioned (cool!), and it does say out-of-spec for 2nd chamber. However, it doesn't correct for elevation. I did find another calculator which does correct for elevation: http://foxed.ca/index.php?page=rotarycalc
In that case, the front rotor (weaker of two) has 101.7, 98.7, and 101.7 normalized. Minimum is 98.6 with standard at 120. So it seems I'm on the lower-end range-wise, but not low enough to warrant a new refurb engine?
Old Feb 18, 2012 | 12:34 PM
1.3_LittersOfFurry's Avatar
Flame On!
Looks close
I use this chart;
https://www.rx8club.com/attachment.p...6&d=1266716801
Old Mar 8, 2012 | 09:27 AM
Footman's Avatar
Dodging those Corollas
^ I concur that is a better chart (more legit)
Old Mar 9, 2012 | 12:42 AM
I would agree with this conclusion. How many miles are currently on your engine?
Just past 100k now. Did the test prior to 100k. For an engine with no premix regimen, a few engine flooding throughout its lifetime, I guess it's not too bad.
gwailo
May 14, 2024 06:57 AM
Shnifty
23
Dec 18, 2015 12:49 PM
TJSiegrist
Sep 10, 2015 09:29 AM
rxwilly8
Sep 2, 2015 02:42 PM
