NW RX-8 Forum Serving WA, OR, ID, AK
Drifting the RX8...issues?
Old Feb 12, 2012 | 04:19 PM
VashCloud's Avatar
Tuner Alliance CEO
So I took my car to a drift practice yesterday, ive drifted it before fine....but this time I had a little above a quarter tank. After I started to warm up doing figure 8's the car started losing power. Just like a fuel cut. Once second im sliding, the next the engine bogs down and no power. As soon as I lift off gas and try again I can slide until it happens again.
What would cause this issue? I went and got gas and filled her up but still had same issue. Is the stock fuel pump THAT weak?!?!?
Also I threw a oil light even though when I checked it i was topped off....
Old Feb 12, 2012 | 04:34 PM
TANKERG's Avatar
Mr. Örange
If the oil light came on, then it was probably the engine saving itself. Low oil pressure and low oil levels will cut power too. If the oil was topped off, then you might want to get the oil pump tested. I don't think it had anything to do with the fuel.
Old Feb 12, 2012 | 04:35 PM
rickeo's Avatar
running on double cream!
We'll need a little more history of your car/motor before we can even begin to help. Any why not post in the correct sub-forum?
Mileage on coils/plugs/wires?
Old Feb 12, 2012 | 04:52 PM
VashCloud's Avatar
Tuner Alliance CEO
Cause I know the NW people and they know my car. Plus its easy to ask friends I know whom race/drift their cars than strangers whom usually talk out their ***....sad but true.
About 3k. I just replaced with BHR ignition set in Late December. And new iridium plugs.
Car has 103k on it. Compress test at 96k was fine.
Old Feb 12, 2012 | 07:17 PM
TANKERG's Avatar
Mr. Örange
Anyone else know what would cause oil starvation if the oil is full?
What sub-forum did you want him to post in?
Old Feb 12, 2012 | 07:20 PM
rickeo's Avatar
Possibly the Troubleshooting section due to the nature of the question... just a thought.
Old Feb 13, 2012 | 06:31 AM
TANKERG's Avatar
Mr. Örange
gotcha
Old Feb 13, 2012 | 07:45 PM
dondo's Avatar
100% baller (finally!)
the fuel pump is weak. which direction were you turning when it happened or does it happen both ways?
Old Feb 13, 2012 | 07:54 PM
pdxhak's Avatar
Official Post Whore
^+1
Old Feb 13, 2012 | 08:17 PM
VashCloud's Avatar
Tuner Alliance CEO
both,
Old Feb 13, 2012 | 08:35 PM
TANKERG's Avatar
Mr. Örange
Then why the oil light?
Old Feb 13, 2012 | 09:54 PM
dondo's Avatar
sloshing around? I get that sometimes too on big bumps where the car lifts up a bit.
Old Feb 13, 2012 | 10:15 PM
TANKERG's Avatar
Mr. Örange
So my question is: can you have a fuel starvation event and the engIne not shut off?
I've had a fuel starvation event on the track, but that was caused by driving down to .5 gallons. The light was on, but the needle was artificially high because of the turns. The engine shut off due to a lack of fuel.
An oil starvation event cuts power, but does not kill the engine.
Last edited by TANKERG; Feb 13, 2012 at 11:28 PM. Reason: Changed the wording of the question.
Old Feb 14, 2012 | 12:29 AM
FazdaRX_8's Avatar
There are no baffles in the oil pan, so when pulling hard turns (Gs) it will slosh and the oil pickup wont be supmerged and get air.
Old Feb 14, 2012 | 07:45 AM
VashCloud's Avatar
Tuner Alliance CEO
In in other words...do I need new fuel pump? I am going supercharged anyway, if so which one? I heard denso is good....OR
Greddy baffled oil pan for only 320 bucks?
Old Feb 14, 2012 | 09:26 AM
FazdaRX_8's Avatar
Yes and yes
Old Feb 14, 2012 | 10:25 AM
dondo's Avatar
yeah you can have fuel starve without the engine shutting down
Old Feb 14, 2012 | 10:26 AM
dondo's Avatar
Yes and yes
does greddy pan solve it? i'm still on the stocker.
Old Feb 14, 2012 | 03:11 PM
FazdaRX_8's Avatar
A person can weld in baffles, I need to look again but my new oil pan from my reman seemed to have a plastic one. Many people who autocross get new oil pans first for all makes and models. Infact I know a guy with an mz3 who autocrossed and oil starved the engine to bearing failure
Old Feb 14, 2012 | 07:08 PM
dondo's Avatar
hmm thats scary
Old Feb 16, 2012 | 07:16 AM
VashCloud's Avatar
Tuner Alliance CEO
Yes it does. Here is the cheapest one you can buy not from me. (btw my business is now official. Tuner Alliance LLC) But I can't sell yet.
http://www.advancespeedshop.com/gred...t-search-us-en
Thats not a bad price its only a 54 dollar mark up from cost.
Here is description:
Functional as a secondary oil cooler, GReddy high-capacity Oil Pans, maintain more constant oil temperatures via increased volume of oil and the improved cooling efficiency of the thick-walled cast aluminum construction. They also include specially designed interiors to keep the oil at the oil pump pick-up for engine reliability.
Also has two plugs for oil metter and for turbo lines already set up.
Old Feb 16, 2012 | 01:41 PM
dondo's Avatar
ok that's good to know. thanks man!
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
nnsoch1776
Jul 22, 2015 04:16 PM
AussieGray
Jul 16, 2015 03:58 AM
Imp
NE RX-8 Forum
May 5, 2004 11:46 AM
RX7FD3
79
Nov 23, 2003 10:52 AM
