4 CEL codes, looking for help
Old Feb 12, 2012 | 03:02 PM
vanross369's Avatar
Question 4 CEL codes, looking for help
I have an 04 and at 86k miles the crank essential seized on me, so I put another engine into it and got it running without being connected to the cat. After connecting it to the cat I found out that the cat was bad (discovered from the glowing red ring) so I replaced it. Turned out I got a new defective cat, so I hollowed out the stock one and made it a mid pipe. I also had to replace the muffler due to damages from the cat.
After everything was put back together I was going gently test it. I started it up and had it running, it idled for at least 30-45 mins, then I reved it to 3-4k RPMs. When I let off the gas it dropped so low it almost died if I didnt hit the gas again. Once I got it to idle again I tried the 3-4k again, but this time it managed to die. Here are the 4 CELs I have P0301, P0171, P0506, and P0336. I did the brake pump and cleared the P0336. Im finally at the end of my wits and knowledge and hope someone here in the community can help.
NOTE: I did all the repairs myself except the muffler which was done at Meinike because I have been in a time crunch.
Old Feb 12, 2012 | 03:21 PM
dozer's Avatar
on his 3rd rx8
p0301 front rotor misfire, P0171 System too lean ON 2 Fuel system,P0506 Idle air control system RPM lower than expected ON 2 CCM,P0336 Eccentric shaft position sensor circuit range/performance problem
well misfires happen when your spark plugs/coils/and wires are going bad, could also be a bat cat, i know you turned it into a midpipe, but something else could be stuck in there.
also i dont understand how having a bad cat can damage your muffler?
Old Feb 12, 2012 | 03:29 PM
vanross369's Avatar
because when it started breaking up part of it dislodged into the muffler clogging it. I knew what the codes came up as, one of the things I was looking for is if someone might know as well if these together might mean something. and when I have the car started the exhaust flows normally from the looks and feel of it.
I also plan on changing the plugs tomorrow to see if that helps any
Old Feb 12, 2012 | 03:30 PM
dozer's Avatar
on his 3rd rx8
well lets see if someone else chimes in, im stumped
Old Feb 12, 2012 | 06:45 PM
vanross369's Avatar
thank you for what you did provide dozer anything is better then nothing any day of the week
Old Feb 12, 2012 | 06:50 PM
StealthTL's Avatar
Metatron
CEL codes are all listed in the tech section.
Sounds like a vacuum leak, and you need to clean the face of the shaft sensor, and reset the shaft sensor memory. All in the DIY section.
Old Feb 23, 2012 | 11:26 AM
vanross369's Avatar
Sorry for the prolonged absence from here, been busy with work and the car. I took off and cleaned the MAF sensor, it has gotten better, it doesnt die as quickly and easy, but once I hit 4k-4.5k RPM is when it will die, Im still getting codes 171 and 506, which I know one is lean fuel and the other air control.
My next step I guess would be fuel injector, is there a way I can remove and see if it is the problem or not?
EDIT: I did change the coils and plugs, that helped with the initial start up.
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
