aem cai install
Old Feb 12, 2012 | 07:23 AM
scottynoshotty's Avatar
aem cai install
So i recently purchased a aem cai, im waiting for it to arrive and i was looking for a DIY for the install on here. im sure it will come with instructions but ive seen some of the DIYs on here and theyve been very helpful with everything else ive done. ill be sure to document my steps(and screw ups) as i install it and throw up a complete DIY on here with pics when im done. Any help/tips would be appreciated.
Old Feb 12, 2012 | 07:51 AM
bse50's Avatar
#50
https://www.rx8club.com/series-i-do-yourself-forum-73/new-sheriff-diy-town-228395/
Wrong forum... Anyway installing it is really easy.
Remove the stock airbox assembly, accordion pipe and bumper. Install intake, fit bumper back... job done!
Old Feb 12, 2012 | 08:07 AM
wcs's Avatar
wcs
no agenda
Oooo
Sheriff going to Sheriff
Just delete this thread until you are ready to compile a new one with all your instructions and pictures.
Please read this thread, its very short and too the point. It should give you the clarity you need.
https://www.rx8club.com/showthread.php?t=228395
Old Feb 12, 2012 | 08:43 AM
alnielsen's Avatar
Moved Thread.
When your ready to document your install, then post in the DIY Forum.
There might be one already there. You could also search for Mazdaspeed CAI. It's the same, different name.
Old Feb 12, 2012 | 09:45 AM
WingleBeast's Avatar
HAVOC
The instructions that come with the kit is a pretty good DIY with photos. You should be fine.
Old Feb 12, 2012 | 12:53 PM
appreciate the help.. i do apologize for posting in the wrong thread..noted..anything tricky about removing the bumper?
Old Feb 12, 2012 | 01:06 PM
Not really...undo the bolts that hold the corner lights..undo the fender plastic retainers, undo the 10 bolts on the lower front edge to the undertray....undo the plastic pins and bolts that hold on the radiator diversion plate..then the 4 bolts that hold on the top support of the bumper
carefully seperate the bumper from the car by the healight areas....
Old Feb 12, 2012 | 03:13 PM
You don't actually have to undo the bolts across the front under tray and remove the bumper cover completely to do this
Old Feb 12, 2012 | 03:27 PM
Easy_E1's Avatar
That is your opinion Teamrx8.
This is mine.
I would prefer to remove the bumper cover to gain easy access to the area I need to install the AEM. Taking a few more bolts/screws off to make the install easier is the optimum way.
Leaving the bumper hanging around on the front/undertray of the car is not a good idea in my book. Take the screws out and clear up the opening to remove the front crash bar.
Having been a mechanic for over 40 years I have found that the easier it is to access something, the easier it is to work on. Spend the extra 5 minutes, if that, to remove the bumper cover completely.
Old Feb 12, 2012 | 03:37 PM
Been doing it for seven years including having it sitting this way on jackstands for the last 2 month, but everyone is free to do it their own way
Chad D.'s Avatar
Spinnnnnnnnnnn
I'd also recommend taking the front bumper off. Especially if it's your first time. Then to change/clean the filter next time you may not need to separate the undertray. Good luck!
Old Feb 12, 2012 | 04:39 PM
rickeo's Avatar
running on double cream!
Having just completed an install of the AEM intake, I cannot fathom how it can be completed without removing the bumper cover, especially to remove the crash bar. However, if Team says it can be done I doubt he's lying. I'll definitely try it when I have to replace the filter.
Old Feb 12, 2012 | 08:58 PM
I don't necessarily expect an uber-n00ber to do it the first time through. I just threw it out there for those who might be interested in some common sense advice. I don't care if it is 5 seconds, 5 minutes, or 5 hours of savings. If there is a faster, easier way to do something without any negative impact then that's the way I will do it. Somebody working in a limited space might like to know they don't gave to figure where to put the bumper cover where it also won't get scratched, damaged, or be in the way for them to trip over it everytime they turn around.
Old Feb 14, 2012 | 10:52 PM
I suppose if you have never considered or done it a certain way it may not make sense. I just happened to have mine apart with the shrouding on top of the bumper support removed for some other work. You can clearly see how accessible it is by just pulling the bumper cover out some the way I described above
Old Feb 15, 2012 | 01:02 AM
Interesting. What are you hiding under that towel man? :no homo:
Old Feb 17, 2012 | 05:32 AM
my imagination ....
Old Feb 17, 2012 | 06:05 AM
ZumnRx8's Avatar
RX8 & RX7 owner
Tape up your headlights and fenders to avoid scratching them when taking off your bumper.
Old Feb 17, 2012 | 06:17 AM
bse50's Avatar
#50
if you scratch your fenders and headlights with a bumper removal you'd be better off not doing any car work, or the car may request a restraining order against you!
Old Feb 17, 2012 | 06:59 AM
poopy happens, at least in the real world ...
Old Feb 17, 2012 | 07:07 AM
bse50's Avatar
#50
Poop is overheating brakes and going straight, not being able to pull a bumper without damage qualifies under a different category.
Old Feb 17, 2012 | 10:54 AM
ZumnRx8's Avatar
RX8 & RX7 owner
^ just saying because it's his first time, and I think he is doing it by himself. The bumper sometimes want to do funny things, like scratch a headlight when it flexes when corners are being taken off the retaining bracket.
poop does happen
Old Feb 17, 2012 | 06:32 PM
appreciate it zumn..it is my first time and im also doing it by myself so ill definetly make sure nothing gets scratched up
Old Feb 18, 2012 | 12:29 PM
so do ignorant replies, apparently you never had to work in a cramped one car garage with kids or a dog running around, or you never accidentally dropped or tripped over anything in your entire life as an illustrious God among the rest of us mere mortals ...
Old Feb 18, 2012 | 12:54 PM
bse50's Avatar
#50
I tripped on many things, even bent a fender because i fell on my car. However this doesn't relate to remove a bumper which can be done in the middle of the street in less than 30 minutes.
You have to take a broader approach to this discussion because you have no specific arguments. Stop blaming others for who you are.
Old Feb 19, 2012 | 04:18 PM
wow..this really escalated quickly
