Pulling P2004 code - APV stuck open
Old Feb 5, 2012 | 11:39 AM
denisizzle's Avatar
I just bought an 04 rx8 and after driving it a few hundred kms I am getting a P2004 code - apv stuck open. It feels perfectly fine but is there a relatively easy way to fix this? Is it hurting the car if I drive with this problem? Thanks.
Old Feb 7, 2012 | 12:31 AM
denisizzle's Avatar
Code turned off for about 200 kms and then came back on recently. It reads as pending and DTC on the code reader. So is this just a minor problem, any ideas how much it will cost a dealer to fix or should I check it out myself?
Old Jun 20, 2012 | 02:26 AM
Wolfe's Avatar
Yellow looks faster.
Im going through the same thing right now. Did you find anything out about it? get it fixed? I called a Mazda dealership for quotes. 400 in labor. lol. dont think so.
Old Jun 21, 2012 | 03:00 PM
lchaidez's Avatar
Caliente
It doesnt hurt your car, it just makes your car run leaner or more rich, i forget which - but it should be fine, in other words it wont break your car. It wont pass emissions though atleast here in CA.
Mine fixed during a decarb process. Error is no longer there nor is it in the Pending errors section.
Car runs fine now.
Old Jun 21, 2012 | 09:51 PM
Wolfe's Avatar
Car runs fine now.
Yea my inspection is coming up in winter. What did you decarb with? seafoam? Im going to get my car tuned up this coming week. I will do a decarb before it goes in, or while its at the shop. Hopefully if it goes away so I can get back to dealing with important things that may be wrong with car. I need brake pads, and I want to put drilled/slotted rotors on it. Also need to save money to pay off car each month. Long time coming till I get enough for cool stuff.
Old Jun 22, 2012 | 12:13 AM
lchaidez's Avatar
Caliente
Smile
Actually, my car got that error before a visit to Mazda to pick up oem coils i ordered. While there i had Mazda decarb it for me with the "Zoom zoom" stuff - you can ask a mazda tech they should know what it is, i didnt bother asking because i got a loaner and went back to work. About a 1.5 hour process and 2 cans worth, i think. After that car's idle was like new, smooth rev's, car over all felt like it had just gone through an rebuild.
Check it out, sometimes they can do it if you can convince them its warranty work, i got it done because i knew the service manager in Santa Monica, too bad as of April, the dealership is gone haha.
Old Jun 22, 2012 | 12:19 AM
The search function work wonders. If it is malfunctioning it will effect power and drivability. now search, it has been discussed at length, a bazillion times.
WranglerFan
Nov 5, 2017 09:35 AM
Shnifty
23
Dec 18, 2015 12:49 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
