Needing knowledge on "Excessive blow by..."
Old Feb 3, 2012 | 01:46 PM
Lizard2974's Avatar
Hi all! I have a used 2005 Mazda RX8 with 36,000. Just bought it in Sept of 2011. My dealership is, let's just say, not great,(Just look at the old air-filter, they said they replaced a month ago) NOT!! So I have taken it to a mechanic that I've used for years and they do know the RX8 well. I love this car! I just recently had the oil changed, 3 weeks ago to be exact, with 5w20 and the oil was not overfilled. The oil is between the marks on the dipstick.
And just after 3 weeks,I'm getting significant oil in the airbox and under the airbox in the tray. (See pics)
I've heard to check MAF, massive air flow, and SSV? I am new to this type
of engine, so needing to know what to check first? Little things, valves sticking maybe? Oil sending unit?
"Trying to save your pocket money and your engine"=PRICELESS
Any help would be greatly appreciated!
Thanks in advance!
LeadFootLady
Attached Thumbnails Needing knowledge on "Excessive blow by..."-airboxtrayrx8oil2-1-12.jpg   Needing knowledge on "Excessive blow by..."-airductrx82-1-12.jpg   Needing knowledge on "Excessive blow by..."-airfilterblowbyrx8.jpg   Needing knowledge on "Excessive blow by..."-rx8airfilteroilblowby.jpg   Needing knowledge on "Excessive blow by..."-rx8.jpg
Old Feb 3, 2012 | 01:57 PM
paimon.soror's Avatar
did you use a long funnel to pour the oil in? if not possibility that you poured oil and some got in the vac tube that leads to the intake.
Old Feb 3, 2012 | 01:59 PM
alnielsen's Avatar
Exhaust back pressure can also force oil to get into the intake area. It did when one of my cats went bad and plugged up.
Old Feb 4, 2012 | 07:26 AM
Lizard2974's Avatar
I don't think I have exhaust back pressure. How could I tell? Should I have my catalytic converter checked out? Or can I check it? Is there a way to test it?
Thanks! This really helps me out!
Old Feb 4, 2012 | 07:36 AM
Lizard2974's Avatar
I wish It was as simple as that...but no over spill. I don't add oil to the tube, is that where you use the long funnel?, I just unscrew the oil cap and add it there, I never use a funnel. Guess I'm a good pourer. LOL And the oil change place did a real clean job. I double checked with a flashlight.
Could there be something else clogged?
Side note: No fuel screen in the RX8, correct?
Last side note: Only 91 Octane the manual says. I used 93, is this going to
be bad in the short or long term?
I also just changed my "in cabin" filters. So with a new air filter, I hate knowing that it will just get oiled until I can find and resolve the problem.
Thanks soo much for the reply! Sometimes it can be the simplest thing.
Old Feb 4, 2012 | 08:21 AM
olddragger's Avatar
search guy--also assured that some oil is getting into the vacuum tube that leads back to the intake.
The only time we have seen bad blowby is when we track and sustained high rpm.
You do realize we have kinda a dry sump system in this engine.
Old Feb 4, 2012 | 09:10 AM
We do? We have a very shallow oil pan....but far from anything that resembles a dry dump
Old Feb 4, 2012 | 02:28 PM
You still haven't learned to read OD-speak yet?
Old Feb 4, 2012 | 02:33 PM
This is actually a Tech Garage thread. Not sure why you would post in the Engine Tuning forum? Please try to learn the website forum organization and post your questions in the proper area.
Excessive blow-by is a symptom of low compression. A proper compression test will tell the tale.
Old Feb 5, 2012 | 08:52 AM
olddragger's Avatar
no we dont have a true dry sump--but we dont have a crankcase either---its kinda in between?
Teams right OP the correct section would be the tech.
Old Feb 5, 2012 | 11:46 AM
Lizard2974's Avatar
I'm sorry I posted in the wrong area. I am new to the site. I see now where this post should have been put. And yes, I'm still learning things about the rotary engine. Heck, I'm trying here. I just purchased it in Sept 2011. (See I thought that when I go to shut the car off, and graceful get the rpm's up to 4000 and then turn the ignition off, that may be why oil was in my air box and vacuum tube)
Always learning something new here! Thanks for all of your help.
Old Jan 24, 2019 | 09:43 AM
Serpentx5's Avatar
I beg the differ. My previous RX8 automatic had the worst compression out there. It would barely even start but when it did, there was no blow by or sight of blue smoke.
Old Jan 24, 2019 | 09:52 AM
Loki's Avatar
Depends on the mode of failure. But your sample of one aside, oil in the intake is a sign of blowby, is a common sign that side seals are on their way out.
You wouldn't see oil smoke out of the tailpipe in most failure scenarios, rotaries don't make that easy.
Also, a 7 year old post? really?
patriotjj
Oct 30, 2016 09:21 AM
Nem
Apr 11, 2013 02:05 PM
EricB
Jan 22, 2013 01:03 AM
remerson1
Jun 6, 2008 11:28 AM
BlueEyes
General Automotive
9
Oct 4, 2005 10:37 PM
