Huge oil leak !!
Old Jan 18, 2012 | 08:32 AM
sticke3's Avatar
Huge oil leak !!
Hello
I'm wondering if some of the rotor geeks may be ae to shed some light on a problem I have ?
Yesterday I topped my beautiful 8 up with oil, it was just above the low mark. I use 5/30 semi synthetic...I then went for a little run..
Now I think it important to say that I have been noticing a little patch of oil on my drive, only a few drops over night.
On my return to my house I parked on my drive and stayed there for a couple of hours. When I went to go to work I drove off of my drive and to my horror a huge mass of oil the size of my engine bay was on the driveway... So I immediately parked back up.. Oil pressure was fine and on checking the oil again found it to be just above the low mark again. ??????
On looking at my engine today it's hard to tell where it's coming from because the entire engine is covered in oil ( it was clean and dry yesterday ) please has anyone any ideas as at the moment it's seems quite a daunting task even finding where it's coming from.. Although my oil catch tank breather seemed to be saturated !!!!!!!
Old Jan 18, 2012 | 08:34 AM
RotaryTherapy's Avatar
ditch the 5W30 go to 10W30 and report back.
Old Jan 18, 2012 | 08:38 AM
wcs's Avatar
wcs
no agenda
First thing: Year, Model, Mileage, modifications (aka Oil Catch Tank Breather)
Let me get this straight. You found a huge oil leak under your car so you started it up?
Are you I-N-S-A-N-E?!?!?!?!?!?!?!?
Second:
Unless you have a aftermarket gauge installed the Oil gauge on the Dash does not display pressure (at least in the Series I)
So have you checked anything yet?
Did you put the dipstick back?
How about the Oil Cap?
There was a TSB for corrosion on the Oil Cooler Lines.
What's an oil catch tank breather?
Old Jan 18, 2012 | 09:00 AM
sticke3's Avatar
Only found leak when car was moved !!!!! 2004 80000 miles, from the uk so no warratys or recalls and my oil catch tank breather looks like an induction kit but only 2 inches round !!
sticke3's Avatar
So no not insane ..
Old Jan 18, 2012 | 09:09 AM
wcs's Avatar
wcs
no agenda
^^^ LOL
Touche' I indeed read it wrong.
Your still going to have to dig in and get dirty to see what's wrong, unless you take it to a mechanic.
The Oil Cooler Lines are known to corrode
Could be the OMP leaking
The OMP is located near the front on the passenger side
Old Jan 18, 2012 | 09:23 AM
paimon.soror's Avatar
Shouldn't be related to his problem.
Like WCS stated, check the oil cooler lines for corrosion. You mentioned that you always saw few drops of oil in the driveway, that should have been an alert to you since this motor lives and dies by its oil consumption.
Old Jan 18, 2012 | 09:34 AM
sticke3's Avatar
Indeed it was am alert !! It's only been like this for around 3 days then BAMB emptied most of the contents on the floor ( but only after I topped it up ). Looks like it's time to get dirty
Old Jan 18, 2012 | 09:42 AM
wcs's Avatar
wcs
no agenda
Well you can always just hope you did a terrible job pouring oil into the filler tube.
If your not careful when adding oil the oil can actually travel the lower edge just inside the filler tube.
The edge connects to the nipple at the top of the filler cap which has a tube that runs to the intake according tube.
Sounds like your setup is a bit different.
Anyways ... if this happens and you are pouring a lot of oil in the filler tube and not being careful it can make quite a mess in the according tube.
Maybe you filled that weird Oil Breather thing with oil and it blew out all over the place.
Just something to consider....
Looks like you're getting dirty either way! SWEET!
Old Jan 18, 2012 | 09:46 AM
wcs's Avatar
wcs
no agenda
Any chance you could post some PICS?
Old Jan 18, 2012 | 09:59 AM
Silver_Surfer's Avatar
I4NI
IN
The last time I read a thread like this the owner was filling his engine and checking his auto trans dip stick.
Old Jan 18, 2012 | 10:09 AM
sticke3's Avatar
As soon as I work out how to paste pics I'll upload for you all
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
WranglerFan
May 31, 2022 07:51 AM
Azki23
Jun 27, 2018 03:48 PM
WranglerFan
Nov 5, 2017 09:35 AM
