Engine will die when the clutch pedal is pressed
Old Jan 17, 2012 | 05:09 PM
sauceyI986's Avatar
Right now my car is in the shop its been there for a little bit right now there trying to figure out why the car dies when the clutch pressed.*
The car will only stay On and running when it has been *push started. *Then it will shut right off after the gas has been pressed on does the car does not rev any insight
Old Jan 17, 2012 | 05:43 PM
Does it idle fine?
Old Jan 17, 2012 | 06:05 PM
Try and explain it a bit better....
Old Jan 17, 2012 | 06:48 PM
sauceyI986's Avatar
It idles around 2000rpm there is no fluctuation at all in the idle but as soon as a little gas is applied or the clutch pedal is pressed in to change gears the motor will die out. The motors sounds good exhaust sounds good at idle. No backfire or anything like that what so ever all the connections have been checked even the injectors or were they are need to be. Just stumped don't know what to do.
Old Jan 19, 2012 | 12:33 AM
sauceyI986's Avatar
Ok in trying to pin point this Dam problem today it idles at 3000 rpm but when the gas predal there is no response the computer reads that the pedal is in working order
The computer also reads that the throttle body is open at 16% on start up. I thinking it must be a throttle body issue I don't know or a disruptive flow in the current
Old Jan 21, 2012 | 10:12 AM
Chino_rx3's Avatar
Gulf Coast Rotaries
Clean TB, maf and check vacums ..
Old Apr 13, 2017 | 06:28 PM
Dustin Michael Meece's Avatar
What was the issues here I'm having similar problems
what did this end up being ?
Old Apr 21, 2017 | 01:40 PM
NotAPreppie's Avatar
What am I doing here?
User's last activity was 11/2014. I doubt you'll get an answer.
Though, if the car idled at 2000 rpm, it had issues.
Old Jun 7, 2025 | 11:11 PM
JoMilla's Avatar
Coolio.
having similar issue. Appears to be a dead thread. If you are researching this issue I will post my results to: https://www.rx8club.com/series-i-tro...ressed-215537/
Skyl3r
Dec 2, 2019 04:51 PM
Tailicus
Sep 2, 2015 12:38 PM
thewatcher101
Aug 4, 2015 10:42 AM
Rx8Lovin
Jul 25, 2015 08:39 PM
RX7.9
Jul 20, 2015 12:01 PM
