eagle talon turbo on automatic RX8
Old Jan 5, 2012 | 12:11 PM
Harrison Jones rx8's Avatar
I can get my hands on a Turbo from an eagle talon was wondering if it would work on my 2005 rx8 a/t
Old Jan 5, 2012 | 12:12 PM
Chris's Avatar
Turbo Member
first of all, why would you want to use a 14+ year old turbo on your car?
Old Jan 5, 2012 | 12:14 PM
because its affordable
Old Jan 5, 2012 | 12:15 PM
RX8Soldier's Avatar
Time for boost...
you can't search to figure out how to turn off your traction, now you're asking this?
Old Jan 5, 2012 | 12:17 PM
RIWWP's Avatar
I gather you believe that a turbo is just tossed under the hood and doesn't include a single supporting piece of hardware, and even if it did, that all supporting hardware is identical for all turbos, including identical mounting points, identical clearances, identical flange sizes and bolt hole patterns, etc...
ANY turbo will "work" with the RX-8 if you have every single piece of supporting hardware that allows it to be mounted correctly in an acceptable location, allows for correct exhaust and air flow piping, correct wiring, correct oil feeds. Some turbo's might now have the most ideal flow characteristics, but you can physically get anything to 'work', given enough customization.
How much are you prepared to do?
Considering your traction control thread, I'm guessing the answer is "not much".
Old Jan 5, 2012 | 12:24 PM
Chris's Avatar
Turbo Member
I do not normally say this, but I would not recommend trying any "cheap" route when trying to turbo the renesis.
When I went turbo I managed to stay very affordable and I used products developed for the RX8.
I am all for customization, but cheap directions end in cheap results.
Old Jan 5, 2012 | 12:25 PM
Yeah I kinda figured that . I donno this is my first time trying to do anything like this. I have background in electrical, plumbing, hvac, but no automotive. I kinda figured that with all the rigging I have to do in my other careers I could maybe make something happen. I guess i just need to figure out what all I need to make a turbo work haha. like I said ive never done anything beside change brake pads cv joints master break Cylinder break booster pump and change oil. so Im kinda clueless
Old Jan 5, 2012 | 12:26 PM
Ricky SE3P's Avatar
Project Seca
why not save yourself the embarrassment and go back to playing need for speed or pocket pool or something.
Old Jan 5, 2012 | 12:27 PM
RXeligion's Avatar
The X is silent
In short: "Not if you have to ask."
oh replaced fuel pump and fuel filters also
Old Jan 5, 2012 | 12:29 PM
RIWWP's Avatar
Go over the Major Horsepower Upgrades subforum and read every single sticky at the top. Then sit back and decide if it's something that you have the finances and energy for.
99% of people that start a thread asking about it never do it. Most of the people that do end up creating a part-out thread within 6 months and then disappearing.
You will spend more than your car is worth getting it turbo'ed.
Old Jan 5, 2012 | 12:30 PM
StealthTL's Avatar
Metatron
The biggest problem is the exhaust manifold - how to plumb all those little ports to the hot side of the turbo.
If you make it short, there is very little room to work down there, so most designs bring it all up and forward into the battery space, then make another header to get it back to the exhaust system.
Just that little item will cost you thousands and many welding hours.
Old Jan 5, 2012 | 12:34 PM
RIWWP's Avatar
But I have good news!
You can increase your horsepower by 20% by trading in your automatic for a manual!
And it will not cost you all that much. It's your cheapest possible power increase. (seriously)
Old Jan 5, 2012 | 01:06 PM
zoom44's Avatar
thread closed.
Quato_jr
Aug 4, 2015 09:22 AM
ShadowGryphon
Jul 29, 2015 05:40 PM
marc2820
Jul 26, 2015 10:47 PM
Bamaham
Jul 23, 2015 08:08 AM
Thechosen1
Jul 22, 2015 11:17 PM
