Importing Rx8
Old Jan 1, 2012 | 09:30 AM
doriibabes's Avatar
ON Importing Rx8
dose anyone know if i bought an Rx8 from the states and brought it to canada what are the charges? the rx8 in canada rates are getting low and dont want to take the chances of losing on opportunity.
Old Jan 1, 2012 | 11:04 AM
RX8Soldier's Avatar
Time for boost...
you could try this method
Old Jan 1, 2012 | 10:06 PM
Marc_GS's Avatar
Hooked on go-fast crack
One thing you should research is DRL (daytime running lights) requirements for licensing the car in Canada. The US cars don't have this. Canadian cars have a DRL module that replaces the high-beam control module on US cars. Unfortunately, the wiring is NOT the same in the two cars, so you can't just plug the Canadian DRL box into a US car.
I know for a fact that several RX-8s have been brought into Canada from the states, so it is possible. I just strongly advise that you figure this out before you actually buy a car.
Old Jan 3, 2012 | 03:24 PM
Nd4SpdSe's Avatar
RIP Mx-3. Hello Rx-8!
You just need some sort of lights. When my mechanic used to work for Canadian Tire, they had the contract to take care of the cars that came across the border, he said he on some cars the easiest thing was to just wire up so the headlights are on all the time. If your 8 had HID's, than maybe you might not want to do this to burn them out sooner since the high-beam is just a regular run of the mill bulb and cheaper to replace, but it would be an easy quick solution.
Old Jan 4, 2012 | 02:02 AM
Thief's Avatar
Reppin Lightning Yellow
Could always wire the fogs up to the accessory position as well.
Old Jan 5, 2012 | 03:44 PM
doriibabes's Avatar
Ok what about Quebec? Other provinces in Ontario.... Trusted ?
mariohardleft
Sep 13, 2015 11:17 PM
Supernaut6
Aug 11, 2015 07:28 PM
Lee_1420
Aug 10, 2015 01:05 PM
robd1337
Jul 31, 2015 09:35 PM
marc2820
Jul 26, 2015 10:47 PM
