Fuel Pump ring what happens when you use screw driver and hammer with anger
Old Dec 27, 2011 | 11:03 PM
RX8_'s Avatar
NZ Fuel Pump ring what happens when you use screw driver and hammer with anger
This is what happens
Mazda part
Doesn't it look nice
Total Damage: 1hr labour, 45min drive to the dealer and $101.60 NZD
Therefore try not to use hammer and flat headed screw driver.
Old Dec 27, 2011 | 11:10 PM
It breaking like that is better than all the tabs breaking off which has happened.
Old Dec 27, 2011 | 11:21 PM
RX8_'s Avatar
When the first two tabs broke off we decided to chop it in half. Believe it or not it was all done with a flat headed screw driver. I guess Mazda was smart to tight like that this way people like me go out to buy a new one for $101.60.
Old Dec 28, 2011 | 02:35 AM
Wingznut's Avatar
Go Red Wings!
They make a tool that attaches to a ratchet, to remove those. (Not that anyone at home would ever have one. )
Also, it looks like you were hitting the tabs on the inside of the ring. A better method would be to hit the outer part of the tabs, and to rotate around the ring... A smack or two on one tab, move 150°, etc. It just kind of binds if you stay on the same side of the ring. Penetrating oil can help, as well. Also, use a pry bar or large square punch, something less likely to chisel through the plastic.
Just some tips to help the next guy.
Old Dec 28, 2011 | 02:52 PM
PeteInLongBeach's Avatar
$20 tool is better than buying a new ring:
Amazon Amazon
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Warrior777
Jun 24, 2019 04:47 PM
HMSS013
Aug 28, 2015 03:02 PM
ShadowGryphon
Aug 23, 2015 02:46 PM
dbarber
Jul 25, 2015 01:34 PM
