SE RX-8 Forum Serving NC, SC, GA, FL, AL, TN
PBOC/PCA Winterfest Autocross Challenge @ SEBRING
Old Dec 27, 2011 | 09:10 PM
cavemancan's Avatar
The forgestar be with you
FL PBOC/PCA Winterfest Autocross Challenge @ SEBRING
Event: PBOC/PCA Winterfest Autocross Challenge @ SEBRING
Roster: Link
REGISTER: LINK
Note: To register please visit www.clubregistration.net search for autocross events under PCA GOLD COAST REGION.
Club Gold Coast Region PCA Registrar rsralex@gmail.com
Dates: 01/14/12 - 01/15/12
Registration Opens/Closes:
- 11/20/11 12:00 AM (members) (central time zone)
- 11/20/11 (all)
- 01/09/12 (closes) (12:00am central time zone)
Who's going:
1) Cavemancan (+1 Sharing a room with a friend...No Homo...Possibly Holiday Inn...Pending Confirmation @ end of week)
2) Scolon
3)
4)
5)
6)
7)
8)
9)
10)
Old Dec 28, 2011 | 12:03 AM
scolon's Avatar
I might be signing up soon. Ill let you know about the hotel thing. My pops is thinking about coming.
Old Dec 28, 2011 | 05:36 PM
Rx8Les's Avatar
Zoom-Zoom
i would love to go! I dont think i can make it...
Old Dec 28, 2011 | 08:59 PM
Ricky SE3P's Avatar
Project Seca
wait its in january? **** i thought it was in feb or march.. ill have to see if i have the money for this with it being so soon and if my camera will even be here in time
Old Dec 29, 2011 | 05:55 PM
scolon's Avatar
I requested the days off at work. On the paper where it says reason I put "drivers ed"
Edit: My request has been approved
Edit^2:
1) Cavemancan
2)Scolon
Old Dec 31, 2011 | 11:47 AM
firecran's Avatar
Renesis out... REW in
Not going to make it this time.... I'll be in Orlando that weekend.
I hope to make the next one.
Old Jan 4, 2012 | 02:46 PM
cavemancan's Avatar
Bump...less gooooo
Old Jan 5, 2012 | 12:54 AM
scolon's Avatar
Originally Posted by cavemancan
Bump...less gooooo
speaking of bumps...i've hit a big one. My car has been at mazda 2 days now. Still no word from the diagnostic they've been trying to do on it. I think my engine has seen the light.
Old Jan 5, 2012 | 11:50 AM
Ricky SE3P's Avatar
Project Seca
your engine is gone bro. you gotta get your maintenence paperwork together and jus hand it to them so they get get your reman engine.
Old Jan 5, 2012 | 12:02 PM
cavemancan's Avatar
Please provide more information? What happened? What symptoms? Whats it doing? Etc?
Old Jan 5, 2012 | 12:31 PM
Ricky SE3P's Avatar
Project Seca
Today was a bad day. My car was driving fine all day until I was on my way home. A little more than a mile away from my house, my car starts to sputter like its misfiring when I go past half throttle. So I left off the gas some but it eventually starts to sputter again until I can't even touch the pedal. So then I'm coasting in neutral when the car just dies so I pull into an empty lot. I try to start her up but the car sounds horrible and barely worked hard enough to stay on. So I let it cool off for a few hrs. I come back and it starts but it sounds like ****. I get the car home but now I need to make a date with mazda.
Dude this time it really has me scared. I'm still under warranty but I can't necessarily return my car to stock. I don't have a spare cat lying around or a factory exhaust. My car came with neither of the two. So wish me luck. Ill keep everyone updated. O my did stick was smelling like gas when I pulled it out. idk what that means.
goodbye engine
Old Jan 5, 2012 | 12:40 PM
cavemancan's Avatar
Originally Posted by Xero Ryuu
goodbye engine
Dont pass judgement so easy cause the first quote could easily be ignition (ask me how I know). However, the second post does worry me a bit. If he has gas mixing with oil in the oil pan then not sure. I am not sure that is even possible. Water mixing with oil would make more sense but not sure about gas since oil is injected into the combustion chamber along with gas...there is no way for it to get back into the oil pan.
Maybe a cracked housing would do this? But if this was the case you should be seeing an oil leek or maybe coolant.
Side note...there is a guy on here that sells used Rx8 parts from wrecked Rx8's. I got a used Cat for $175 once and it had 24k miles on the CAT.
Just an FYI.
Old Jan 5, 2012 | 02:18 PM
Ricky SE3P's Avatar
Project Seca
Just an FYI.
Turbo Clinic is parting out a Rx8 right now and im passing by there tomorrow morning for parts...while im there im going to see if that 8 has a cat and if so how much for it. Shane is on his way to mazda right now to speak with them about the car. They are apparently blaming the issue on a clogged cat ( ) and then after that claim, bad coils. They want to charge $120 for compression check under warranty. We'll see what happens next
Old Jan 5, 2012 | 03:07 PM
cavemancan's Avatar
Warrantee does not cover diagnostics so he will need to pony up the cash for the compression check. He also needs to make sure the ignition system is in working order (I.E. less than 20k miles...preferably around 10k or less). Once that is done make the dealership call Mazda MNAO if they start making BS claims about what the issue is like a clogged CAT...LMAO
Old Jan 5, 2012 | 09:19 PM
scolon's Avatar
My plugs are brand new. My coils overall were barely a year old but they pointed the finger at em because they were aftermarket knock offs from carquest. So I'm waiting for that to get done and well see.
Old Jan 6, 2012 | 07:28 AM
cavemancan's Avatar
No matter how hard they try to make excuses...If they give you a hard time about a part...Replace it with the stock item and insist they warrantee the engine. Once everything is stock and they try to give you BS like water in the gas etc...Insist on a phone call with Mazda MNAO. They will be forced to abide by MNAO's decission.
Old Jan 10, 2012 | 06:48 PM
scolon's Avatar
Im sorry to inform but unfortunately I wont be able to make it out this weekend. I started school this week and I now have a saturday class that i can't miss. I'm so bummed =(
Old Jan 10, 2012 | 08:42 PM
cavemancan's Avatar
That is not a status on your engine mister sir guy dude...????
Old Jan 10, 2012 | 08:51 PM
Ricky SE3P's Avatar
Project Seca
Shane; and his engine has returned to health after coils. i gotta give this round to you, you were right his coils were at fault. i believed it was compression but with the simmilarities in symptoms it was a overlooked mistake on my part. kudos Chris none the less; you 2 - me 0 (your first point is having a clutch) lol
Old Jan 11, 2012 | 09:28 AM
scolon's Avatar
Yes and no (I'm really taking a scuba class this semster). I did have my coils replaced so it runs fine now but to a certain extent. When cold it will like new just as it should. However after driving for so long. it will start sound like its gargling and i will lose some power. Idle becomes A LOT rougher as well. It stays like that until it cools all the way down again. It has happened everytime I go and drive.
So i shall be rummaging through the forums in the mean time. Any shared knowledge would be helpful. Sorry to thread jack lol
Old Jan 12, 2012 | 01:14 PM
cavemancan's Avatar
I officially now think you have compression issues. This is exactly how it happened to me. Go to Mazda Pros and get them to do a compression check then take it to Mazda and they will most likely force you to pay a diagnostic fee to do the same compression check. I say this so you have proof that it's low on compression in case they try to lie or deter you from getting a new engine. I think Mazda Pro's charged me less than $100 (Maybe $60 or $70).
Are your spark plugs new as well?? Cables? If you have a whole new ignition system and it's running like crap during normal opperating temps but fine when colder it tells me there is a seal issue and temperature change is making it more obvious. It's not carbon either cause if it was it would happen when cold. If temperature is the interesting variable then I do think compression is the culprit.
Old Jan 12, 2012 | 07:24 PM
scolon's Avatar
Went to autozone to read my codes and i got another misfire in rotor #2. I just pulled out all my spark plugs and cleaned and tested them all. I replaced them all in august except 1. I also replaced a trailing spark plug in the 2nd rotor since it looked bad.
The car still has a terrible idle although start up have gotten a bit better.
My cables are the magnecor brand and are about a year old so about 15000 miles on them. My next thing is to moniter my cooling levels.
Could you send me the info for Mazda Pros? I've never heard of them.
Old Jan 12, 2012 | 08:23 PM
cavemancan's Avatar
Yeah...talk to Edger and tell him Chris with the Rx8 sent ya.
954-364-4344
P.S. next time if you replace plugs you should always replace them all at once. From what I've read so far the life span for the plugs start to die out in the neighborhood of 20k miles with spirited driving.
hufflepuff
May 30, 2016 10:45 AM
archon
Oct 1, 2015 06:08 AM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
