Inside Light Flickering
Old Dec 13, 2011 | 09:38 AM
Globetrahter's Avatar
I am now sure how to word this but at time when I open my door, either door, my car's lights flash rapidly and makes like a clicking noise. It does not happen every single time but enough that I notice/
I heard from 2 people it maybe some wires and not a fuse because a fuse would either work or wouldnt work..
Any Clues?
Old Dec 13, 2011 | 11:46 AM
FastFreddy61's Avatar
Im not sure if the interior light runs through a relay, if it does, could be the relay is playing up.You are refering to the interior light ?
Last edited by FastFreddy61; Dec 13, 2011 at 11:48 AM. Reason: clarification of which light
Old Dec 13, 2011 | 12:01 PM
StealthTL's Avatar
Metatron
Sounds like your car has the vibration sensor option on the alarm. Module is behind the passenger side footpanel, high up and secured to the wire bundle there. Adjuster **** on the side.
Old Dec 13, 2011 | 12:06 PM
Thanks Stealth, I just learned something else useful.
Old Dec 13, 2011 | 12:16 PM
paimon.soror's Avatar
I am not sure that is what is happening here as I too have the shock sensor and it doesn't trigger any flashing lights or clicking. Granted if the car is armed it will set off the alarm.
Old Dec 13, 2011 | 11:37 PM
Yeah very weird, I dont know
Old Dec 14, 2011 | 09:30 AM
dynamho's Avatar
OP, when you say your "car's lights", do you mean the interior lights?
If so, the flickering is caused by release of the door switch? Door switch is the switch covered with rubber in the door jamb that tells the body control module (or whatever) that the door is closed.
I'd start targeting the problem from there.
I had a faulty door switch replaced very early when I purchased my car new and it had similar issues to the one you described.
Old Dec 14, 2011 | 02:42 PM
StealthTL's Avatar
Metatron
Mine used to do that, I think the problem was an early design of the shock module - it would chatter like that (but not actually alarm) as I got out and closed the doors. There was a redesign that added a delay, I think.
Old Dec 14, 2011 | 03:31 PM
^^ Oh wow...good to know
vapor2
May 4, 2020 03:53 AM
chadsta
Sep 20, 2015 11:00 PM
gt4uk
Sep 20, 2015 07:19 PM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
