Oil coming out with water
Old Dec 8, 2011 | 04:29 PM
Fast8's Avatar
Had to repost this
So my car heated up the other day. Not to the point where it started shaking or doing strange noises.
i saw that the temperature rised, and i automatically stopped and turned off the car. I didn't have anti-freeze at hand, so i poured water.
The next day my car didn't turn on. Later i see that the car was leaking and it looked like was oil with water
Old Dec 8, 2011 | 04:33 PM
RIWWP's Avatar
I answered this once, did you not like my answer?
I still have the same response.
Old Dec 8, 2011 | 04:36 PM
Arca_ex's Avatar
BECAUSE RACECAR
Coolant seals unsandwhiched, time for a new motor.
Old Dec 8, 2011 | 04:39 PM
Fast8's Avatar
ha yes but it was on general automotive
oh man not a new motor
i'll look at it again and i'll take pictures
Old Dec 8, 2011 | 04:51 PM
RIWWP's Avatar
Yeah, your only hope is that it is oil coming from broken/busted/rusted oil lines and separately coolant coming from water hoses.
Coming together from a single failure can only be a cracked or warped block, and since the block carries the water and oil through internal passages, these would then mingle... warping a housing from overheating isn't an unheard of result of overheating.
Old Dec 8, 2011 | 05:01 PM
Fast8's Avatar
Hopefully.
Yeah right now, after work, I'll take a look at those hoses and oil lines.
thanks RIWWP
Old Dec 8, 2011 | 05:30 PM
ShinkaEvo's Avatar
Triangular Bee Hive
Overheated, new motor period.
OE temp gauge only tell u when do u need to get a new motor.
If the coolant is gone, then means you've got leak somewhere, fix that too.
Old Dec 8, 2011 | 05:34 PM
RIWWP's Avatar
This isn't quite accurate. If nothing else you aren't recognizing that a warped housing would create a gap in the cooling jacket running through the motor as well as in the oil passages. They are likely the same source.
It is also possible for an overheat to not immediately fry the motor, even with the needle moving.
But yes, once it moves, the temp it is seeing is usually fatal. Usually. Not always.
Old Dec 8, 2011 | 06:11 PM
TrevorsTII's Avatar
Registered Badass
Originally Posted by Fast8
Had to repost this
Same thing happened to me with my FC. I will attach a pic of what may have happened to you. But I had my coolant getting pushed in my overflow due to it happening on my compression side. See pic. Very common, and probably your situation. NEW MOTOR!
Old Dec 8, 2011 | 11:18 PM
Fast8's Avatar
going to have to take a to a shop then
but no one here in Laredo, Texas knows about rotors
ANY RECOMMENDATIONS
here in south texas?
Old Dec 9, 2011 | 01:09 AM
TX
ANY RECOMMENDATIONS
Dealer, or come up to SA. You do know there is an 8 year 100k miles Mazda warranty on the engine right?
Old Dec 9, 2011 | 10:10 AM
Fast8's Avatar
Oh really!
I'll stop by this afternoon at my local dealership, but I'm not the original owner.
Old Dec 9, 2011 | 10:14 AM
TX
Oh really!
Dude, read the sticky threads. How do you buy a RX-8 without knowing about the engine issues?
Old Dec 9, 2011 | 11:07 AM
Fast8's Avatar
Alright thanks.
I'll take a look at them right now.
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
drebbrnator
Dec 27, 2018 07:02 PM
talonhart2
Aug 26, 2015 04:14 PM
Yayforaddison
38
Jul 31, 2015 11:28 AM
Davey's RX-8
Jul 28, 2015 12:13 PM
