Transmission/Clutch Issue after Starting!!
Old Dec 7, 2011 | 02:40 AM
usafellis's Avatar
I recently had the Exedy stage one clutch and light weight flywheel installed in my car. When I start the vehicle it is hard to shift into gear, or if I am in a gear (say 1st) It is hard to get out of it. This problem persists on for about 5 minutes or so. After the vehicle is warmed up you can push it into a gear and drive. After driving for a mile or so the feel is completely gone. What is happening here? The longer I don't drive it the more time it needs to be put into gear to drive. Bad throw out bearing? I have looked at other threads and have found nothing like this problem I have. Thanks for the help.
Old Dec 7, 2011 | 08:53 AM
FastFreddy61's Avatar
If you cracked open the clutch line and had to bleed it, some time it takes a few bleeding's, how much clutch pedal free play is there ?
Audio Concepts ATL
Sep 26, 2021 01:59 PM
9krpmrx8
Nov 5, 2015 11:45 PM
learningdriver
Aug 8, 2015 06:55 AM
dbarber
Jul 25, 2015 01:34 PM
Bomba
Jul 22, 2015 06:46 AM
