steering locked up WTF!!!
Old Dec 5, 2011 | 07:01 PM
thecrazy8's Avatar
so messing around the other day in a place they frown at drifting and
i spin out and my hand slips off the steering wheel
the wheel goes spinning out of control to the left and hits the bump stop hard
now i cant turn the wheels at all stuck completely to the left
did i mess something up in the rack or???
Old Dec 5, 2011 | 07:06 PM
StealthTL's Avatar
Metatron
So I guess your plan for a 20B with twin turbos is on hold now?
Old Dec 5, 2011 | 07:22 PM
thecrazy8's Avatar
Ya for now keep running into stupid problems that are costing me out the ***
Old Dec 5, 2011 | 08:36 PM
lordagrabah's Avatar
I hate it when that happens. Just when I'm about to build the most epic car ever.
Old Dec 5, 2011 | 08:39 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Have you tried jiggling the wheel back and forth? Sometimes the steering wheel lock mechanism gets a little out of alignment and won't let you turn the steering. Also there should be a way to bypass this interlock.
Old Dec 5, 2011 | 11:02 PM
sjschutz's Avatar
Big Poppa Steve
You're just too damn crazy!
Old Dec 6, 2011 | 05:49 AM
Wingznut's Avatar
Go Red Wings!
Gonna have to crawl underneath and inspect for any damage.
Old Dec 6, 2011 | 08:15 AM
thecrazy8's Avatar
ok so have it on the lift disconnected the steering column from rack tried to turn the rack by hand and nothing
no obvious damage no fluid leaks nothing
when i get the rack out ill keep you all updated
Old Dec 6, 2011 | 08:21 AM
RIWWP's Avatar
I'd be quite intrigued if there was fluid leaking.
You either damaged something internal to the $2,000 steering rack or somehow engaged the steering lock in the column. I've disassembled my steering shaft from the wheel to the joint before the rack, and there is nothing else that could hold it to one side.
I am making the assumption that you dont have a wheel embedded in the frame.
Old Dec 6, 2011 | 08:32 AM
paimon.soror's Avatar
You activated the "i drive like an idiot because I am cool" lock. The lock will release after you calm the f&ck down and drive like a responsible adult.
thecrazy8's Avatar
and the steering wheel moves freely with no issues
Old Dec 6, 2011 | 08:37 AM
RIWWP's Avatar
Wait, the steering wheel rotates but the front wheels dont?
You definately broke something. Check the upper joint and shaft splines, lower joint and shaft splines, the shafts themselves. If turning the steering wheel makes the lower joint and rack input shaft turn, congratulations, you have to replace your steering rack.
If you are lucky, you only snapped a steering shaft, joint, or stripped the shaft splines at one of the joints.
Old Dec 6, 2011 | 08:53 AM
Wingznut's Avatar
Go Red Wings!
No, he's saying that with the steering column disconnected, the steering wheel moves freely, but the rack/wheels don't.
Old Dec 6, 2011 | 09:36 AM
thecrazy8's Avatar
to you all who actually post a helping hand thank you to those (paimon.soror) who just talk **** go to a different forum or facebook
so the rack housing is cracked a pic on my profile the inner tie rod end on the right side jammed into the housing.
Old Dec 6, 2011 | 09:47 AM
thecrazy8's Avatar
FIGURE OUT THE PROBLEM!
when the steering wheel snapped left it wedged the inner t.r.e. into the rack housing compressing it and cracking it have it free now
gonna see if anyone in town can weld the cracks
ill let you all know how it goes
Old Dec 6, 2011 | 09:50 AM
fuztupnz's Avatar
Phone Booth'd
Looks like you'll be needing a new rack. Start checking the Part out threads and hope for a good deal. Mazmart may be able to help you out as well. It's not going to be cheap. I doubt you'll find anyone to weld the rack for you, nor would i advise you to. Good luck.
You're getting **** because you started off your thread admitting to being reckless in a place that frowns on it. A lot of people feel it's a ding on our community to have people doing stupid **** in places they shouldn't. I encourage it. The more wrecked cars means the more parts I can get for cheap.
Old Dec 6, 2011 | 11:51 AM
RIWWP's Avatar
This.
Old Dec 6, 2011 | 01:05 PM
bhammer's Avatar
Not an UnRegistered User
Agree 100%, we have to share the road.
Gives us late 30's guys a bad name. Same way I feel about those m/c guys doing wheelies down the highway.
There is always a time a place for that stuff but not on the public roads.
Old Dec 7, 2011 | 10:21 AM
thecrazy8's Avatar
It was in a loading dock lot when no one was around don't do it out on public roads
Too much risk
Old Dec 7, 2011 | 12:44 PM
I guess you think you're such a good driver that you don't need two hands on the wheel ... you do know that Fast & Furious is just made up Hollywood BS, don't you?
Old Dec 7, 2011 | 07:54 PM
thecrazy8's Avatar
It's called shifting but you probably drive an automatic cause you can't drive a manual
So don't talk you bullsh?t at me
Old Dec 7, 2011 | 08:19 PM
RIWWP's Avatar
Not much shifting while drifting.
And Team races his RX-8, which is very common knowledge on here, so your attempt to throw it back at his just looks humorous and immature.
YOU are the one who caused this, and it is yet another example of our beloved 8 falling into the hands of someone who doesnt deserve it and trashes it out of ignorance, negligence, or stupidity.
Look, here is another: https://www.rx8club.com/showthread.p...68#post4140368
So yeah, you disgust us to one degree or another, and it's bound to show.
Old Dec 7, 2011 | 08:53 PM
Too much risk
Well that surely worked in your favor
Old Dec 7, 2011 | 09:07 PM
thecrazy8's Avatar
Everyone is bound to make mistakes **** happens
That's how you learn but I guess the rest of you were just born
Knowing everything I get it now thanks
Old Dec 7, 2011 | 11:42 PM
The Reverend's Avatar
That's a lie
lol is this guy 12 or just developmentally challenged
