Help! I need to know what a rabbit chewed off in my car
Old Dec 3, 2011 | 01:56 PM
gablekevin's Avatar
Well i went to my car to leave my parents from visiting for thanksgiving. My car is completely dead and i was stumped by how that was possible, then i open my hood and a huge rabbit jumps out from atop the area in question and i find 2 wires completely chewed through that go to who knows what.
Can someone please help me identify what wires were chewed through and what connector needs to be replaced.
Im kinda stuck here until i can get this fixed
Thanks Everyone
Old Dec 3, 2011 | 02:01 PM
wcs's Avatar
wcs
no agenda
Sorry but that's funny.
I'm not sure what that is ... I should know, but I don't, sorry.
I will guess it's a vacuum sensor.
And Bump!
Dewd needs help, somebody?
edit:
Just looked it up in the manual.
Its the Purge Solenoid Valve
Old Dec 3, 2011 | 02:04 PM
RIWWP's Avatar
Holy huge picture and humorously worded title.
I don't think it would be critical for the car to start and should only affect ECU operation while running, however, shorted sensor wires can blow fuses. Start checking your fuse box for any of them blown. My money is going to be on the Engine fuse, which typically is upstream for the power that feeds the sensors, as well as other critical bits. I blew the Engine fuse on my Miata when I accidentally shorted the sensor wires for the rear O2 sensor.
I could entirely be wrong though. I'd recommend protecting those wires from each other before attempting to re-start though.
Old Dec 3, 2011 | 02:05 PM
wcs's Avatar
wcs
no agenda
HA! Beat you on this one Sir!
edit:
But if you could explain WTF exactly a purge solenoid valve does, that would be most excellent dude.
Old Dec 3, 2011 | 02:06 PM
RIWWP's Avatar
I took time to go out to my 8 and take a picture of what 'normal' looks like
Still on my Xoom though . Trying to figure out how to attach directly from the tablet, mostly from curiosity.
Old Dec 3, 2011 | 02:20 PM
wcs's Avatar
wcs
no agenda
So it's been 20 minutes since his help I'm stuck here post.
Figure he's walked over to the strip joint and said "F" the car?
Old Dec 3, 2011 | 02:22 PM
RIWWP's Avatar
He could be out at the car, came in to post that, and went back out to try to figure it out and hasn't re-checked yet.
I do that all the time.
Old Dec 3, 2011 | 02:36 PM
achangho's Avatar
Firewalker
Isn't anyone wondering how the rabbit got in there, all the way to the top? I can barely fit my hand through the crevices under the hood, much less an animal!
Old Dec 3, 2011 | 02:37 PM
RIWWP's Avatar
Not really. Rabbits aren't much bigger than rats in actual muscle and structure. Just hellaplush fur.
Old Dec 3, 2011 | 02:45 PM
gablekevin's Avatar
ok so i checked that fuse and its fine so i guess i will hook the battery up to the charger and see where that gets me
Old Dec 3, 2011 | 02:47 PM
gablekevin's Avatar
im so afraid that the battery is going to be fine and that more than just a few wires got chewed up
Old Dec 3, 2011 | 02:48 PM
RIWWP's Avatar
Did you check them ALL? Just about every fuse in the engine compartment fuse box is capable of preventing the car from starting. I don't know for sure which one that particular sensor runs through.
And definitely shield those wires from each other and neighboring objects (tape each up and/or snip the ends clean and then tape) before attempting to start.
Old Dec 3, 2011 | 03:05 PM
gablekevin's Avatar
no sorry i didnt check them all( i will do that now) but its not just a matter of the car not starting. I mean it is dead no lights anywhere. And the battery charger is showing a partial charge at least.
Old Dec 3, 2011 | 03:07 PM
RIWWP's Avatar
A fuse can do that too. Check the ones in the footwell at the front edge of the driver's door near the footrest next to the clutch as well.
Something is blocking battery power completely, and that is usually a fuse, unless there is another major wire that was chewed through.
Old Dec 3, 2011 | 03:23 PM
gablekevin's Avatar
i checked all the fuses in the engine box but everything points to that (sensor) only reason i think that because that wire loom is tied into the same one that goes to the alternator. Car worked fine before this was chewed up and battery charger showed some charge on the battery itself so hopefully that is it. I checked out the area as best as possible from above and it didnt look like any thing else was chewed
Old Dec 3, 2011 | 03:47 PM
wcs's Avatar
wcs
no agenda
Maybe you should just go back to the strip joint
Old Dec 3, 2011 | 04:31 PM
gablekevin's Avatar
well we soldered some wires as best as possible to what was left of that connector and tried the battery and still nothing. i also used a fuse tester on all fuses inside and in the engine compartment. Im running out of ideas and i have no money to get it checked out.
Man those bunnies really f***ed things up for me
Old Dec 4, 2011 | 12:23 PM
Did you check the main fuse at the battery positive cable post connection?
Old Dec 4, 2011 | 12:38 PM
Those chewed off before? The butt connectors are from a previous repair?
You sure have some kind of rodent problem
Old Dec 4, 2011 | 01:39 PM
MS Addict's Avatar
Needz moar Mazdaspeed.
Check the battery cables, up to the fuse block especially. As well as the harness going into your dash, specifically to the ignition. If you're not getting anything anywhere, it's going to be in that circuit, or a mass ground got chewed somewhere. Could be the battery's ground.
Old May 16, 2012 | 08:22 PM
gablekevin's Avatar
sorry to thread resurrect but the same thing happened again(rodent chewed on wires same as above) and it is now unfixable at least as far as making another butt connection with the wiring so now i need to order a replacement connector as shown in the pictures below does anyone no where to look or possibly a link would be super helpful for a replacement connector.Name:  T2RW3.jpg
Old May 16, 2012 | 08:57 PM
RIWWP's Avatar
Try Paul at Mazmart. A dealer might want to charge you for the entire harness.
Perhaps a part-out on here or a junkyard 8, where the harness isn't wanted, you can cut out the part you need.
Old May 16, 2012 | 09:50 PM
New Yorker's Avatar
Oh, I wondered. Then I remembered; a good magician never reveals his secret.
Old May 16, 2012 | 09:51 PM
What plug is it? I have a scrap engine harness if it is off there??
Old May 17, 2012 | 02:18 PM
gablekevin's Avatar
its the plug that goes into the purge solenoid valve. Thats also the same plug thats circled above .
I know seriously i dont even know how these rabbits do it, twice for that matter.
