Fresh installs but now car won't turn over
Old Nov 30, 2011 | 10:10 AM
DisPak's Avatar
hey guys, ive just installed at new radiator, coolent tempurature sensor , and thermosat.. now the car wont turn over.. everything comes on and it tires to turn over but wont. any ideas ?
Old Nov 30, 2011 | 10:33 AM
Old Rotor's Avatar
Check your battery voltage and it's connections.
Old Nov 30, 2011 | 10:37 AM
DisPak's Avatar
Btw the car hasn't over heated .. I had some scillcone hoses I never installed .. Then broke a plastic hose nipple in the process .. So I installed a new rad , thermosat , cts just to get some fresh parts in there .. Maybe I forgot to hook up some sensor or a fuse is blown? I'm going back in there right now so any thoughts would be great
Old Nov 30, 2011 | 10:39 AM
DisPak's Avatar
I don't have volt meter but I left the battery hooked up since last night .. I just tired to crank up and it seems weaker than last night
Old Nov 30, 2011 | 11:07 AM
Old Rotor's Avatar
Put a charger on the battery. Meters are cheap ten bucks. Take it out and have it checked. Push start if it's manual.
Old Nov 30, 2011 | 11:43 AM
DisPak's Avatar
Ok i'll give a try .. Battery I'd fairly new .. 6 months the most
Old Nov 30, 2011 | 01:54 PM
DisPak's Avatar
Just came back from testing battery but it came out fine.. So it's not the battery.. I did have to disconnect the alternator before when I changed the coolent temp sensor .. Something's wrong with the Alternator?
Old Nov 30, 2011 | 01:56 PM
Should start without an alternator really....but if you didn't hook all the wires back up that could be your problem
Check that the battery connectiona are good as well
Old Nov 30, 2011 | 03:59 PM
Bladecutter's Avatar
Rockie Mountain Newbie
What does this mean?
Does this mean that when you turn the ignition key, that nothing happens?
Or, does this mean that when you turn the ignition key, the engine cranks, but doesn't fire up?
BC.
Old Nov 30, 2011 | 04:38 PM
ShinkaEvo's Avatar
Triangular Bee Hive
Jump start?
Old Nov 30, 2011 | 04:53 PM
DisPak's Avatar
Ikddkd
It tires to crank
up but it doesn't start .. I'm going to try a push start when there's less cars on the road
Old Dec 1, 2011 | 10:13 AM
DisPak's Avatar
Ok so it won't jump start .. So I removed the spark plugs and their foul like hell .. I forgot to mention that I had changed the spark plug wires a week before to the maztrix wires .. Guess their too strong for my old plugs . I'm going to change them tonight and see if the car will start. .
Old Dec 1, 2011 | 10:42 AM
MS Addict's Avatar
Needz moar Mazdaspeed.
Fouled as in excess fuel on them? That'd be insufficient spark. You can try the other wires, it might work, but I don't know.
Make sure all your connections to the ignition coils are tight. As well as your wires are connected good too.
Old Dec 1, 2011 | 12:01 PM
DisPak's Avatar
yea the fouled with fuel .. The plugs are not new .. About 1 1/2 year old .. I'm going to buy the laser ngk plugs ..
Old Dec 2, 2011 | 05:02 PM
DisPak's Avatar
Well just replaced the spark plugs .. Car still doesn't start .. Could it be the coils? The car cranks but doesn't start .. I'm out of ideas guys .. Need some serious help
Old Dec 2, 2011 | 05:56 PM
If its a manual tranny...pull start it. If it is flooded it will start...if it is something else it won't
Old Dec 2, 2011 | 06:28 PM
DisPak's Avatar
yea me and my buddy after we got out of work are going to try to push start it tonight ..
Old Dec 2, 2011 | 07:38 PM
DisPak's Avatar
Or you guys think the engine is flooded?
Old Dec 3, 2011 | 10:54 AM
DisPak's Avatar
Well I tried to de flood engine last night ... I thought it was flooded with fuel but what came out of the spark plug was coolent and gas .. I think my seals are broken ..
Old Dec 3, 2011 | 11:02 AM
RIWWP's Avatar
Yeah, coolant in the engine means one or more coolant seals failed, which means your engine is done. Possibly able to still start, but it will keep getting worse faster and faster as the coolant destroys the surfaces.
Old Dec 3, 2011 | 11:47 AM
DisPak's Avatar
damn that's what I was afraid of ..
Old Dec 3, 2011 | 12:27 PM
StealthTL's Avatar
Metatron
I wondered why you made a point of this statement, up front.
Wishful thinking.
When the engine overheats, the aluminum housings expand almost twice as fast as the 'irons' and the steel bolts holding the block together. The housing crushes itself, then contracts and coolant leaks in.
Don't try just replacing the sealing 'O' rings - the housings are now permanently distorted and useless.
Old Dec 3, 2011 | 06:55 PM
DisPak's Avatar
Yea it was wishful thinking on my part .. I didn't see the themp gauge go up at all .. But I felt the starting to have a little rough idle so I pulled over right away ..
I've been reading about Mazda have an extended warranty program .ssp 77?
You guys think they'll cover my engine?
Old Dec 6, 2011 | 07:22 AM
tofu_box's Avatar
if your car is within the warranty period, but i'd heavily consider putting back a factory radiator/thermostat before you take it in.
If the issue is due to overheating a aftermarket thermostat & radiator can be very good argument for mazda against warranty repairs, even though it was installed after the engine busted and there is no way to prove otherwise.
Old Dec 7, 2011 | 05:43 PM
DisPak's Avatar
yea I've already looked into
it .. There's no way that they'll cover it .. I'm working out a deal with this dude .. New engine and install for $2000
Wantingtoknow
Dec 15, 2016 02:25 PM
rotorocks
47
May 11, 2016 03:23 PM
Ajmurphy85
Jul 30, 2015 07:51 AM
harithac
Jul 25, 2015 04:21 PM
dbarber
Jul 25, 2015 01:34 PM
