Need some help / advise
Old Nov 29, 2011 | 07:53 PM
Viggy's Avatar
First off here's a few things I think the members here should know, I'm security forces in the active Air Force and I just moved up to Nellis AFB in NE. I obviously needed a car and turned to the RX8 for it's obvious bad-assery and Rotary engine. So short story is, I work ALOT and don't get alot of free time. But about a day or two after buying it I noticed that the Check Engine Light started flashing at high RPM's (i'd say only above 6000 while at freeway speeds) while on the freeway. Also I don't know a ton about cars and only a little about rotary engines in general.
The dealer said they just replaced the starter but I don't think that would have much to do with it. There is a slight smell of oil coming in from the vents but also I would guess that's due to a shitty air filter. The light is always flashing and never stays solid and always goes away after I turn the car off. It's probably happened 10 times or just about every time I jump onto the free way.
Also I did lurk to try to find an answer but I really just don't have the time to search thru everything. Car has about 45,000 miles on it and runs fine, no loss of power but also has a minor grind going into 4th gear while in high RPM's
Should I just take it into the dealer or local on base shop to get code error readings? Any help would be much appreciated.
Also as a foot note I hear RX-8s need to be driven quite often and pretty much right after I bought it I learned their is a large chance I will be deployed in January is there anything I need to know about keeping it sitting in holding for a long time or should I just let some of the family here drive it every couple weeks? Thanks again.
Old Nov 29, 2011 | 07:55 PM
StealthTL's Avatar
Metatron
Flashing CEL under power is a (serious) misfire.
Your plugs are due for a replace, if keep your foot on it when it's flashing you'll need a new motor too.
Old Nov 29, 2011 | 08:01 PM
no, first off read this:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-how-use-search-function-rx8club-com-forum-73846/
Old Nov 29, 2011 | 08:07 PM
Viggy's Avatar
I did do a search, and was more inclined due to my general lack of knowledge of cars and rotary engines that perhaps a collective of problems presenting themselves in a combination may possibly direct to a certain type of problem.
Like I said before I do not have any loss of power at all in any of the gears. Now like I was asking would the simplest thing to do be just to take it to the shop and run the error codes immediately or is my situation not that big of a problem and it could probably wait for the weekend?
Old Nov 29, 2011 | 10:43 PM
RX8Soldier's Avatar
Time for boost...
when your car cries for help, it's best not to leave it.
One issue in this car can start of a chain of events that could become critical...
While waiting for the news, I'd recommend reading through the stickies in the forum to get to know your engine better
Old Nov 29, 2011 | 10:50 PM
Viggy's Avatar
Indeed and I plan to become at least competent, I just needed an answer in the mean time for the here and now. It should be ok for another day or two. At least one can hope.
riz_ali
Aug 28, 2015 10:33 PM
HMSS013
Aug 28, 2015 03:02 PM
Klaudio prela
Aug 26, 2015 02:58 PM
mqandil
Mar 26, 2004 04:05 PM
