Can't put car in any gear when car's turned on...
Born Again RX8 Fan
Okay so, here's my story. I was driving my car in a neighborhood going to my girlfriends house and then it became hard to shift cause my clutch stopped disengaging... so I drove it to her house and turned the car off. The car goes in and out of gear fine when off, but when on it won't even budge. Whenever I depress the clutch pedal I can't hear the clutch disengaging and when it's all the way to the floor I can hear a grinding noise coming from under the car which leads me to believe that my throw out bearing is done. I don't think it's my master or my slave because neither of them are leaking, and the clutch pedal still has pressure (although it seems like it may be a little less than before). Anyway, just wondering if I could get any input on this before I dig in and drop the tranny. Thanks in advance.
dont need a new trans.same thing happened to me in vegas at a casino.
had clutch,both bearings, pressure plate replaced and fly wheel surfaced.
not sure if it was the pilot bearing or the throw out bearing, but one them
went out and i could not engage any gears while car was running.
Born Again RX8 Fan
Originally Posted by Bladecutter
Did you look at your clutch pedal bracket to see if its broken?
BC.
BC.
Dokuji
Nov 1, 2016 02:51 PM
