Unsprung weight.
Old Nov 29, 2011 | 01:32 PM
Agent XY's Avatar
Unsprung weight.
Does anyone know the unsprung weight for the stock rx8? I know this will vary on the wheels and tires but those numbers can easily be found.
Even better does anyone know the sprung weight front and rear?
Thanks!!!
Old Nov 29, 2011 | 01:58 PM
Arca_ex's Avatar
BECAUSE RACECAR
Hmm.
Well you'd have to find the weight of your wheels, brake calipers, brake rotors, studs, lug nuts, brake shields, and control arms and that would give you an approximate unsprung weight number, then just subtract that amount from the total weight of the car for sprung weight.
Total weight distribution is like 51/49 front/rear so the sprung weight numbers will probably be close to the same over the front and rear.
Old Nov 29, 2011 | 02:07 PM
bse50's Avatar
#50
There's a thread with a bunch of parts weight. It may help you find some data.
Old Nov 29, 2011 | 03:01 PM
Agent XY's Avatar
Thanks for the info so far. I was hoping someone already had this for the stock car. I might have to bust out the calculator and look up those weights.
Old Nov 29, 2011 | 11:58 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Why you want to know? Just curious.
Old Nov 30, 2011 | 12:17 AM
LifeAfterRx8's Avatar
Originally Posted by Arca_ex
Hmm.
I thought the 8 had a 50/50 weight distribution?
Old Nov 30, 2011 | 12:50 AM
Arca_ex's Avatar
BECAUSE RACECAR
Depends on how much gas you have in it.
Old Nov 30, 2011 | 01:03 AM
Is that with or without driver?
Old Nov 30, 2011 | 10:24 AM
Agent XY's Avatar
I wanted to do some math .
A good web based example.
http://farnorthracing.com/autocross_secrets16.html
And my garage is really small, really uneven, and really cold .
I just wanted some rough numbers to play with.
Old Dec 1, 2011 | 12:08 AM
monchie's Avatar
I HATE SPEEDBUMPS!
I thought the 50/50 weight is just the car...without the driver and gas?
Old Dec 1, 2011 | 12:09 AM
monchie's Avatar
I HATE SPEEDBUMPS!
Just wanted to know, thanks.
Old Apr 13, 2013 | 02:15 PM
HexRX's Avatar
Hexrx
2 year old bump, but yes I am curious about this.
My old Subaru had a ratio of sprung vs unsprung of 7:1 .
Has anyone done the math for the rx8?
crossbow
91
Jul 19, 2012 06:22 AM
brillo
Sep 16, 2005 09:27 PM
rotarynews.com
31
May 24, 2005 09:55 AM
BaronVonBigmeat
12
Aug 24, 2004 01:30 AM
Spin9k
Apr 27, 2004 02:43 PM
