Brake problem
Old Nov 22, 2011 | 06:55 PM
HotBrothers's Avatar
Brake problem
I recently changed my pads and rotors from Rotorpros, and after the replacement,
the Brake kinda got "smooth" and it took more time to stop before the replacement.
I feel like when I push the brake pedal, compared to before replacement, the brake
pedal goes all the way in (steep) causing some difficulties to stop the car.
After the replacement, I drove the car about 400 miles. I also notice that when I
stop in a sudden, some grinding noise comes from the car. (Not the brake pad squeaking noise).
Does my pads and rotors need more time to break-in or do you guys think
there were some kind of mistakes during the replacement?
I will greatly appreciate your feedbacks. Thanks!
Old Nov 22, 2011 | 09:29 PM
lta_ds_fs7's Avatar
Did you bleed the brakes after installing the new pads and rotors?
Old Nov 22, 2011 | 09:40 PM
Arca_ex's Avatar
BECAUSE RACECAR
Did you bleed the system and bed them in properly?
Old Nov 23, 2011 | 09:10 AM
Yes
Old Nov 23, 2011 | 09:59 AM
wrightcomputing's Avatar
Made in England
My thoughts would also have been that they were not bled properly and there is still air in the lines. Were they good quality replacements?
Old Nov 23, 2011 | 10:05 AM
lta_ds_fs7's Avatar
In which order did you bleed the lines?
Old Nov 23, 2011 | 10:58 AM
The rotors and pads were from Rotorpros.. they have pretty good feedbacks by many users of this club.
I called the shop who've done the installation job and they told me to bring the vehicle back... they said they did bleed properly but will see
Old Nov 23, 2011 | 11:01 AM
lta_ds_fs7's Avatar
I see...I was under the impression you did them yourself.
Old Nov 23, 2011 | 12:08 PM
Arca_ex's Avatar
BECAUSE RACECAR
If the shop can't get a simple brake job right the first time I definitely wouldn't be going back there. You should learn how to bleed the brakes yourself, it's not that hard and would be a good learning experience with the car.
Old Nov 23, 2011 | 03:30 PM
I would like to do it by myself but I don't have my own garage and living with host families.
I went to the other shop and guys took the test drive with me, claiming the brake is "tight". They told me it's not related to the bleeding and told me I need to change the "brake booster" which I don't even know what the heck is it for. Labor costs $350 and the part is about $100ish.
Old Nov 23, 2011 | 03:51 PM
c0ldf1ame's Avatar
um i don't know what shops your going to but if your car was braking fine before the change, it shouldn't affect the feel that much after the change, my advice is go to a reputable shop in the area that's not trying to rip you off for parts
Old Nov 23, 2011 | 04:36 PM
I did a lot of research to find a reputable shops and thats the shop I went to (brake booster)
I know I was dumb because I did the rotors/pads job where the labor was the cheapest.
Old Nov 23, 2011 | 05:07 PM
Easy_E1's Avatar
Generally the installation of new pads and rotors would make the brake pedal a bit harder. And pedal travel should be less with the new pads.
If you have more pedal travel and less braking force then you have an issue that I would deem the responsibility of the installer. They did something wrong. Or something they did is not right.
As far as the brake booster going bad right after they did the brakes,,,not likely.
Do us a favor and look at both front and rear rotors and try to determine that they are functioning properly. Note any differences between the rotor surfaces. Do they look like they have all been braking properly? Does the E-Brake function OK?
Old Nov 23, 2011 | 05:31 PM
Thank you so much for your reply. What does the E-brake mean?
Old Nov 23, 2011 | 09:19 PM
Easy_E1's Avatar
Emergency brake/Parking brake. The handle on the right of the gear shift.
Old Nov 23, 2011 | 11:14 PM
Yeap the parking brake works properly. I took a look at the rotor surface and I could not notice something noticeable...When I push the brake pedal, I feel the same deep-ness before the replacement but just takes long to stop... feels like the brake is stopping very smoothly where it should stop suddenly.
Old Nov 24, 2011 | 12:03 AM
Grace_Excel's Avatar
Charles Bundy
I think you need to bed the pads properly. Here's a very informative post about Brake FAQ.
RevMeHarder
Jun 1, 2026 02:30 PM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
wayloco
Sep 1, 2015 09:03 PM
