Weird sound coming from behind center console...
Old Nov 17, 2011 | 02:39 PM
TsM's Avatar
TsM
First, I apologize if this is in the wrong section.
I have an 07 RX8 6 speed with about 41,000 miles on it. Recently the car started making a sound whenever I accelerated. It goes away when the car is in neutral or stopped at a light while in gear.
The best way to describe the sound is it sounds like running water, a CD spinning, or if wind was getting into the engine bay some how. It comes from behind the center console/glove box area. I've also noticed a trend that I notice it more often during cold weather.
Can anyone help me out with this? What is this sound? I'm worried it might develope into a bigger problem. Thanks a lot.
Old Nov 17, 2011 | 02:42 PM
RIWWP's Avatar
It's fluid rushing through the heater core. Entirely common to all RX-8s, and gets more noticeable as ambient temperatures drop.
The RX-8 is quiet enough that you can hear it (and/or less sound absorbing materials).
It isn't hurting anything, there are no concerns of damage or eventual failure, and "fixing" it is a very costly procedure where the dealer will install baffles in the coolant route to eliminate the noise.
Old Nov 17, 2011 | 03:35 PM
TsM's Avatar
TsM
Thank god that's all it is! I appreciate the quick and detailed response!
Old Nov 17, 2011 | 03:53 PM
blazenblue63's Avatar
European livin n ohio
That's what that is? Lmfao! I have heard it a few times and was wondering what it could be. I heard it only with the a/c on though. When it got colder and I stopped using the a/c, it stopped.
Old Nov 17, 2011 | 11:37 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Never heard and never had this problem. If its a common problem, then it should be on the TSB lists.
Old Nov 18, 2011 | 06:31 AM
RIWWP's Avatar
Sigh @ Monchie.
It isn't a problem any more than hearing the wind noise by driving on the highway with the windows down is a problem.
Old Nov 18, 2011 | 02:38 PM
xexok's Avatar
Glad to hear its normal. I did that throttle body coolant line removal DIY and was starting to think that sound was coming from the fitting where I joined the hoses.
sccarally
Gulf RX-8 Forum
Sep 8, 2015 10:34 PM
GrAfiX
Aug 24, 2015 08:08 AM
himynameisDD
Aug 17, 2015 12:40 AM
mazdaverx7
Jul 21, 2015 07:31 PM
ironj221
Jul 16, 2015 10:16 PM
