Exploded View of Model Rotary Engine
Old Mar 7, 2004 | 12:54 AM
neit_jnf's Avatar
exploded view of my model rotary engine for your viewing pleasure
engine
Old Mar 7, 2004 | 12:56 AM
neit_jnf's Avatar
front couterweight in the flywheel
Old Mar 7, 2004 | 12:57 AM
neit_jnf's Avatar
rear counterweight
neit_jnf's Avatar
rear counterweight removed
Old Mar 7, 2004 | 12:58 AM
neit_jnf's Avatar
rear plate removed, you can see the rotor and apex seals, also you can clearly see where is the intake side and exhaust side by the number of cooling fins. There's also the two dowel pins. :D
Old Mar 7, 2004 | 01:04 AM
neit_jnf's Avatar
rear plate with fixed gear
Old Mar 7, 2004 | 01:05 AM
neit_jnf's Avatar
rotor
Old Mar 7, 2004 | 01:06 AM
neit_jnf's Avatar
combustion recess
neit_jnf's Avatar
close up apex seal and spring
Old Mar 7, 2004 | 01:07 AM
neit_jnf's Avatar
eccentric shaft
Old Mar 7, 2004 | 01:10 AM
MazdaManiac's Avatar
OS Rocks!
Too bad I'm only flying 1/4 scale these days. A rotor-powered R/C plane would be cool!
Everything I have is either gas or really huge glow.
Old Mar 7, 2004 | 01:13 AM
neit_jnf's Avatar
rotating assy
Old Mar 7, 2004 | 01:15 AM
neit_jnf's Avatar
rotor housing and front plate with bearing, you can see the glowplug hole it's aprox 1/16 inch diameter!!
Old Mar 7, 2004 | 01:17 AM
neit_jnf's Avatar
And finally, the intake and exhaust ports. They are aprox 1/4 inch diameter
Old Mar 7, 2004 | 01:19 AM
neit_jnf's Avatar
For those wondering, the pink oily substance is just that, oil. I keep them oiled for long life
Old Mar 7, 2004 | 02:14 AM
wakeech's Avatar
mostly harmless
...yeah, i was just going to say that those ports are monsterous!! very awesome.
Old Mar 7, 2004 | 02:24 AM
neit_jnf's Avatar
I was thinking about making them bigger, what do you think?
Old Mar 7, 2004 | 02:26 AM
wakeech's Avatar
mostly harmless
entirely possible, and always better... the sleeves are cast blocks, probably bored out, right??? (they look way bigger from the outside) just bore some more
...just need to adjust the idle screw up a bit... or more... :o
Old Mar 7, 2004 | 02:30 AM
neit_jnf's Avatar
I seriously thought about that but then I'll mess up the intake and exhaust timing, and probably lose some low end :D I thought about maybe widen them to make them more ellipse shaped without going higher or lower on the timing. I need a peri port expert's advise! The outside sleeve's ID is about 7/16 inch and the actual port is 3/16 inch (smaller than the 1/4 inch I previously thought) I would need a different carb or port it too.
Old Mar 7, 2004 | 07:01 AM
Psylence's Avatar
Back in the family
That's so cool! I have wanted to purchase one of those OS Wankels for years.. just never had the right project for it. Would love to swap it into my R/C Heli..
Does it sound any different when its running than a standard .30 2 stroke?
Old Mar 7, 2004 | 07:31 AM
emailists's Avatar
I'm confused. First, why did you pull the engine out of your RX8, and second, why is it so tiny? I mean I knew the Renesis was smaller than other engines, but man that's tiny.
Old Mar 7, 2004 | 07:37 AM
MadMacz's Avatar
That's the coolest. Now all we need is to make 1/4 scale RX-8 kits for our kids.
Old Mar 7, 2004 | 09:09 AM
Psylence's Avatar
Back in the family
Yeah, it'd be pimp to put one of those into an RC car of some sort. The only thing I'm aware of was someone putting one into an RC monster truck..
I looked at my gas powered truck.. looked at the OS Wankel... kept on looking, and still couldn't figure out how to do it
Old Mar 7, 2004 | 10:59 AM
Genom's Avatar
Not so Super right now
It's a single rotor RC engine basoically :D
BTW, that little bugger is cool. Dont forgot to turbocharge it! :D
Old Mar 7, 2004 | 11:03 AM
RX-8 friend's Avatar
At first I thought it was going to turn out to be a Renisis (side ports). Now I'm dissapointed. Even the intake isn't a side port!
Very nice.
