2004 no heat
Old Nov 11, 2011 | 10:16 AM
southernsky's Avatar
2004 no heat
I have a 2004 that will not put out any heat, the factory deck is no longer working and have installed an after market one. Any suggestions
Old Nov 11, 2011 | 12:28 PM
mx0013's Avatar
I had no heat and i pulled out the temp controls out and found cold solder joints re-soldered them then i had heat again there is a way to check the the control with out taking it out it was posted somewhere on this page somewhere
Old Nov 11, 2011 | 12:30 PM
scremn8's Avatar
the more things change
when mine's went out i had heat but no a\c.
i still had a warrty. at that time tho.
Old Nov 12, 2011 | 01:08 PM
BigBrother87's Avatar
Press the "Scan +" and Power button at the same time to show "A/C Temp" on the display. This shows the current position of the baffle, from 0-16. If the display always shows 0, it could be the baffle. I just had to replace mine, $400. Good luck.
Old Nov 12, 2011 | 04:01 PM
zoom44's Avatar
you have an aftermarket head unit?
Old Nov 12, 2011 | 04:41 PM
Easy_E1's Avatar
Old Nov 12, 2011 | 08:16 PM
Cohort's Avatar
where does the head unit fit into this equation?
Old Nov 12, 2011 | 08:40 PM
StealthTL's Avatar
Metatron
Please, please, please read the tech section where this topic has been posted to death, the answer is there for the discovering......
Old Nov 12, 2011 | 09:01 PM
atwood_101's Avatar
If ya aint first yer last
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-no-heat-repair-heater-control-158200/
Took about 1 minute to search this up on my iPhone..
TeslaMSI
Dec 10, 2015 01:10 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
vapor2
Sep 21, 2015 01:36 AM
vapor2
Sep 19, 2015 05:33 PM
vapor2
Sep 8, 2015 08:27 PM
