NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
Weird Sounds
Old Nov 2, 2011 | 02:26 PM
yongxun18's Avatar
MA Weird Sounds
Wow, it's been so long since I've been checking this site regularly...! Anyway, my car has been acting up and making a weird sound. It sounds as though its from the transmission (this loud whirring sound). I know our cars make the "jetsons car" sound naturally but mine sounds a bit abnormal as of late (ALOT louder). I changed my transmission fluid and differential fluid thinking that it was the problem (redline and eneos) but it hasn't changed at all. I was wondering if anyone is blessed with the skill of knowing what's wrong with a car just by the sound or if anyone is around to take a look at it that would be awesome! I live in the Brookline area.
I really hope someone will tell me I'm paranoid and that it's not a serious problem!
Old Nov 2, 2011 | 02:32 PM
RX8Soldier's Avatar
Time for boost...
what type of fluid did you fill up with? Does it happen at speed, under load? Or idling?
Old Nov 2, 2011 | 02:34 PM
RIWWP's Avatar
Can you give any information about when it occurs and when it doesn't occur? If it's transmission related, then typically it will fluctuate or change or appear/disappear based on RPM, wheel speed, and/or clutch engagement.
A quick guess is that it's going to be your throwout bearing (or release bearing, depending on what you call it)
Old Nov 2, 2011 | 02:54 PM
yongxun18's Avatar
I don't think it happens when the car is idling. When I started the car today though, I def heard a loud start which is abnormal. It happens when I'm pressing on the gas or coasting in gear or in neutral.
I used MT-90 redline for the trans fluid and Eneos GL-5 75w90 for the diff
Thanks for the replies!
Old Nov 2, 2011 | 03:02 PM
RIWWP's Avatar
Yeah, my guess would be the throwout bearing.
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Quiggs321
Sep 30, 2015 05:34 PM
Racingjunkie
Sep 29, 2015 05:05 PM
