Weak interior fans
Old Mar 5, 2004 | 12:37 PM
Raevik's Avatar
Weak interior fans
Anyone else get this feeling?
When I have the car's fans set up to blow top and bottom vents, I can crank it to full bore and get LOTS of air noise, but very little air movement.
By little, I do mean I can hold my hand over the upper vents and feel just the very faintest of air movement. When I switch to full front, it blows moderately strong.
Is this normal, or just me?
Old Mar 5, 2004 | 12:48 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
Re: Weak interior fans
When using the front and lower vents together, much of the airflow is directed down and to the rear seats. Some folks have blocked off half or more of the rear ducts that are under the front seats with duct tape, forcing more air to come out of the front vents... you might want to give that a try.
Old Mar 5, 2004 | 12:53 PM
Raevik's Avatar
Would it be hard to upgrade the fan with a more powerful variant so it can handle both?
Old Mar 5, 2004 | 01:22 PM
Spin9k's Avatar
Momentum Keeps Me Going
Re: Re: Weak interior fans
I blocked it (could find only one beneath the drivers seat and it was only a 1"x2" size) completely, and noticed very little, if any, change.
Also took to dealer and said slooowwww warmup in winter, and when really cold here (20 deg and below) sometimes had even a cooldown (yes!).
Dealer checked (something?) and said all was 'normal'.
What I have never figured is why manufacturers don't offer a built in to the heater vents an 'electric pre-warmer' to get you toasty before the engine warms up? That way you would have hot air from the getgo.
Old Mar 5, 2004 | 02:33 PM
G8rboy's Avatar
Re: Re: Re: Weak interior fans
That doesn't sound 'normal' to me... I've started the car up in the morning when it was -5 to -15 to take my kid to school several times in the last two months and had slight heat after 2-3 minutes, and decent warmth after 5 minutes of driving... and I've never felt it cool off. When it's been in the 20's, I get some heat within a couple of blocks. One thing I don't do is let the car warm up in the driveway for more than a minute or two- I've found the only way to get the temp up is to drive it right away.
I'd ask the dealer what the 'normal' parameters are for heat-up... maybe your themostat is getting stuck?
Jst4fun
Mar 5, 2021 07:16 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
Tgiolitto100
Sep 29, 2015 10:52 AM
