Repeated O2 code?
Old Oct 12, 2011 | 07:47 PM
Fetsch's Avatar
Repeated O2 code?
About a month ago I bought a 05 rx8 with 78k miles and after a week I got a o2 code. Replaced the sensor and it popes up again. This time I replaced the plugs and wires. It ran good for a few days but on my half hour drive to work my engine light popes up again. So i pulled in to a gas station and called my mechanic. But I had to wait 30min before it would start. And now every time I pull up to a stop sign it idles low an occasionally shuts down. I have no idea what's causing this. I was told to use 91octane and the guy before me used only synthetic oil. Plus there is a cherping sound when I start to accelerate. I make a few distance drives a month but usually it small town driving and half hour to and from work. Does anyone know y the light keeps popping up. And What should I look for to fix it?
Thank you
Fetsch
Old Oct 12, 2011 | 07:52 PM
RX8Soldier's Avatar
Time for boost...
you need to have the codes read. Without them, it could be a number of things...
Old Oct 12, 2011 | 08:10 PM
Fetsch's Avatar
Every time it reads post catalyst lean. Same code before and after new sensor
Old Oct 12, 2011 | 08:14 PM
RX8Soldier's Avatar
Time for boost...
If you get the actual code, that would help.
Possible issues:
plugs/ coils/ wires not installed properly
eccentric shaft position sensor
O2 sensor
Leak in system
low compression
etc
etc
Old Oct 12, 2011 | 08:37 PM
Fetsch's Avatar
P2096. Is what my mechanic said
Old Oct 12, 2011 | 08:39 PM
Fetsch's Avatar
Well dang now he thinks it's 3027. I'll have it hooked up when I get a chance
Old Oct 12, 2011 | 08:40 PM
fuztupnz's Avatar
Phone Booth'd
Time to pull you cat an check that it isn't melted or clogged. That should have been your first step.
Old Oct 12, 2011 | 08:45 PM
fuztupnz's Avatar
Phone Booth'd
3027? That's a new one for me
Old Oct 12, 2011 | 08:48 PM
Fetsch's Avatar
Ok I'll do that. Plus I read that the coils only last 20k and I'm thinkin I'll check mine.
Old Oct 12, 2011 | 09:35 PM
Fetsch's Avatar
3027 might not even be one. In his defense when I asked him he was juggling kids and a 390 install
RotaryResurrection
13
Jan 19, 2023 01:18 PM
TurboX8
Jul 21, 2016 02:38 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Forevermore
Sep 20, 2015 01:04 PM
LowCG
27
Feb 7, 2008 11:43 AM
