245WPH w/o FI
Old Oct 6, 2011 | 12:45 PM
FungsterRacing's Avatar
Hibernating -.-
245WPH w/o FI
So I found this video on YouTube... not sure if it belongs to a member here..
If you click on his other video's, in one he specifies 245WHP without FI. IMO, this doesn't seem quite right. He does have an 'impressive' list of mods;
"mods are.....light weight wheels, custom intake, ported and polished throttle body, bhr ignition, mazmart water pump, sohn adapter, act prolite flywheel, act clutch, greddy oil pan, underdrive pullies, koyo radiator, racing beat header, dual resonated midpipe, greddy sp2 exhaust, short shifter, and rb race flash. Engine is running on stock internals. Roughly 15,000 on this new engine. Also full suspension work and brakes. Def. one of best running n/a's out there."
What are your thoughts? From this vid and another of his, it is definitely faster than a regular N/A Renesis.
EDIT: Just realized I messed up on the typing for the title. Mean WHP, obviously. Just trying to type too fast
Old Oct 6, 2011 | 12:48 PM
Rotary-RX8's Avatar
Girls who drive stick FTW
its possible. The mods he has dont do much but they do add up.
Old Oct 6, 2011 | 12:50 PM
RIWWP's Avatar
He is likely using a mobile device that is calculating his HP and thinks it means WHP not crank HP.
Several of those things DO help power, but not to the tune of 12hp (5.1%) higher than a fully funded race team with thousands of R+D hours on all parts of the engine, anti-friction coatings on all drivetrain parts, and a $30,000 ECU that has posted the highest NA power on the forums.
Old Oct 6, 2011 | 12:51 PM
Are-Ex-Eight's Avatar
Nice Rotors
Impressive no seatbelt and flat tire launch.
Old Oct 6, 2011 | 12:57 PM
Hibernating -.-
That's true... but....
This seems viable. But he also claims "Almost 300hp at the crank". But for an exact number like 245, I'm guessing his numbers are only an assumption based on claimed gains by each particular aftermarket item; which we all know is never quite the reality
Old Oct 6, 2011 | 01:00 PM
200.mph's Avatar
FULLY SEMI AUTOMATIC
^my wheels are aftermarket and my tpms is always on. on another note he states na, maby hes spraying. maby he dynoed on the bottle?
Old Oct 6, 2011 | 01:37 PM
pdxhak's Avatar
Official Post Whore
The owner is FOS if he thinks his car is putting down 245whp.
This is what he posted on one of his other vids.
I removed alot of **** and replaced existing with lightweight wheels....just wheels, spare and battery i lost almost 65 pounds...I replaced alot of parts. I know someone with a scrap yard and that's what it weighed with half tank and no driver.......so ill run with it.......and it is pretty quick buddy.....weight makes much difference..
x2004rx8 3 weeks ago
245 hp to the wheel. Almost 300 at crank. All n/a. Car is 2845 lbs.
Old Oct 6, 2011 | 01:43 PM
Old Oct 6, 2011 | 01:49 PM
HockeyRX-8's Avatar
TNC
Old Oct 6, 2011 | 01:54 PM
PhillipM's Avatar
My wheels don't even fit an RX8, that's gotta be worth +30bhp, right?
Old Oct 6, 2011 | 02:36 PM
steezy_11's Avatar
Zoom Zoom
The highest N/A whp I've seen was 218 whp / 183wtq and many people said getting any higher is almost impossible. He had much more mods than this guy has. There is a dyno of it somewhere on here but I cant remember where.
Old Oct 6, 2011 | 02:41 PM
Originally Posted by steezy_11
The highest N/A whp I've seen was 208 whp and many people said getting any higher is almost impossible. He had much more mods than this guy has. There is a dyno of it somewhere on here but I cant remember where.
race teams and vendors aside, most don't see that kind of HP. (above 220 NA)
I've dyno'd at almost 210whp but we had a car at last year's SoCal Dyno Day put down 218 whp. The motor was freshly rebuilt by the owner, was ported and had a ton of NA mods.
Old Oct 6, 2011 | 02:42 PM
MazdaManiac's Avatar
Then you haven't seen much.
245 is possible, but not from the guy in the vid.
225 is the highest you will typically see in a properly set-up car.
Old Oct 6, 2011 | 02:45 PM
RIWWP's Avatar
If you don't go that route, then the most you can expect is about 200 whp without a custom engine rebuild, which can run you $5,000+ once you factor in the labor of pulling and reinstalling the engine and the shipping. The advancements in porting work have been slow coming, but they are still moving the needle upwards.
BDC has taken the new top N/A dyno (non-race team funded) posted on 5/16/2011 here: https://www.rx8club.com/series-i-major-horsepower-upgrades-93/bdc-street-port-vs-stock-port-dyno-comparison-216762/ 223whp:
Please note that "heavy" has not been defined as of this edit. The gains are from more than 1 source. Likely full 3 inch headers to tips on the exhaust, entirely unknown what the intake is. The porting work above was mostly on the intake ports rather than the exhaust ports. There was also likely significant improvement in the seal tolerances over factory specs.
Eric Meyer posted his 233hp dyno sheet here: https://www.rx8club.com/series-i-major-horsepower-upgrades-93/233-rwhp-dyno-sheet-218322/
But keep in mind that it's likely his team invested $100,000+ (just a guess) into the R+D of the engine and drivetrain to get it there (including special treatments of the transmission and diff to reduce drivetrain loss)
Old Oct 6, 2011 | 02:59 PM
Supernaut6's Avatar
I'd like to know what dyno all these numbers are coming from. They can vary greatly.
Old Oct 6, 2011 | 03:06 PM
My dyno and the 218whp car (shadycrew) were done on a dyno jet here in SoCal.
SR Motorcars to be exact.
I've used that shop for years and have literally dyno'd over 100 RX-8's on it so I'd say it's pretty accurate.
oh, and that's where AEM dyno's their cars as does BMI and their nifty 4 rotor rx8.
not sure about the rest but there definitely can be variances from dyno to dyno based on location and even what type of dyno. mustang vs dynojet differ quite a bit as well.
Old Oct 6, 2011 | 03:11 PM
RIWWP's Avatar
Jedi was able to crank out ...what was it? 1,000whp on that dyno with his 8?
I'd say it's pretty accurate then.
<<nudge nudge... lol>>
Old Oct 6, 2011 | 03:13 PM
get it right *******, it was 1,500 whp but that was running nitro meth so that doesn't really count.
Old Oct 6, 2011 | 03:24 PM
Originally Posted by Jedi54
get it right *******, it was 1,500 whp but I was sniffing nitro meth so that doesn't really count.
Fixed.
Old Oct 6, 2011 | 08:14 PM
NYC Drift King's Avatar
Supercharged by Pettit
Oh wow 245 n/a no way...
Old Oct 6, 2011 | 10:51 PM
Easy_E1's Avatar
Old Oct 6, 2011 | 11:16 PM
Hibernating -.-
Originally Posted by Easy_E1
Weirdest thing Easy_E1 - I looked at your picture and immediately got a wiff of Kool-Aid. Whatever the hell your using in your avatar, I want it
Old Oct 6, 2011 | 11:25 PM
Easy_E1's Avatar
I'll send you some BHR Koolaid with your next order.
Old Oct 6, 2011 | 11:29 PM
Hibernating -.-
BHR Midpipe and BHR Kool-Aid.... I am going to be expecting this in my next order now you know
Old Oct 7, 2011 | 02:47 PM
philipchan's Avatar
lol...without FI? no way man...
just thinking we are making 232 hp to the crank,
if u can get close to that, is very impressive
but if u are talking abt with ANY FI mod, just bolt on mods,
and u can get more whp than what u got on the crank? that's impossible IMO
