Will the XXR 527 18x9.5's fit on the RX8? A lowered RX8?
Old Oct 3, 2011 | 04:31 PM
Tai-Stik's Avatar
There are a couple threads about these inexpensive wheel here, but not of this particular size:
Fitment: 18x9.75 +20 5x100/5x4.5
http://lsdmotorsports.com/prod/901117048019.html
Good Win recommends 45mm-48mm offset for 18x9.5, so using these would require spacers unless there's another size (or wheel) that would be a better fit.
http://www.good-win-racing.com/Mazda...els-Tires.html
Any thoughts of the best inexpensive route to 18x9.5's on the RX8 lowered with Koni Yellows and S-techs and tire sizes from 255-265-275/35/18's?
I've also been eyeballing these super cheap tires that some of my professional driver friend's have recommended:
http://www.directbuytire.com/product-p/14fm8afa.htm
Of course rolling rear fenders makes me slightly nervous...
Old Oct 3, 2011 | 04:32 PM
RX8Soldier's Avatar
Time for boost...
read the stickies
Old Oct 3, 2011 | 04:39 PM
RX8inSTL's Avatar
Adam
Those wont fit without a lot of negative camber on S Techs, if you were on coilovers and much lower they would fit no problem.
That size tire is gonna take quite a bit of work to make work, if youre nervous about rolling fenders I suggest not doing this because you will have to do a lot more than just that.
And are your "professional racing" friends drifters? Because I dont think anyone else would use those tires other than someone just looking for a cheap tire to burn up.
My advice to you get something in the +35 to +40 range, it will be less work.
What are you trying to acheive anyway?
EDIT: Forgot to mention who cares if its not the same wheel. There are a lot of threads with that wheel size in them, the brand makes no difference.
Old Oct 3, 2011 | 04:45 PM
Oh yay, another RX8 with XXR's.
Old Oct 3, 2011 | 04:47 PM
RX8inSTL's Avatar
Adam
And Federals......
Not that my wheels are expensive or anything but im sure we will be seeing them more and more often now.
Old Oct 3, 2011 | 05:33 PM
Tai-Stik's Avatar
Thanks for the feedback; I would like to have excellent grip and good looks on a mostly daily driven 8 that would hit the mountain once a week or so and occasionally to the track.
I've noticed 18x9.5's with 255+/35/18 tires is popular among JDM tuners, so I am aiming for something like this but on an obvious budget.
What else in addition to rolling the rear fenders plus spacers would need to be done if I went with this wheel/tire combo?
Old Oct 3, 2011 | 05:40 PM
RX8Soldier's Avatar
Time for boost...
read the stickies
Old Oct 3, 2011 | 06:12 PM
Tai-Stik's Avatar
Perhaps you could enlighten me when searching for info here. Searching via google reveals hundreds of threads with bits and pieces of information which may or may not be accurate. The FAQ is not a wiki here either (like it is on some sites) so perhaps I'm missing something.
- Thanks
Old Oct 3, 2011 | 06:23 PM
Highway8's Avatar
Registered RX8 Nut
First off. A spacer will space the wheel out farther from the car which is what you would need if you had a +65mm offset but need a +45MM offset. So spacers are not an option here.
Second, here are 2 links I found in 30 seconds simply by clicking "Wheels, tires, Brakes and Suspension" and scrolling down.
First you have a thread which is labled a sticky The Will it fit thread
and a little far down The Aggressive Wheel Fitment Thread
Old Oct 3, 2011 | 06:26 PM
RX8Soldier's Avatar
Time for boost...
^Highway to the rescue!
OP, in the sub-forum that you posted (as a matter of fact, in ALL sub-forums), there are threads at the top of each page with a "sticky" note in front. Read all of those in each sub-forum before posting a new thread
Old Oct 3, 2011 | 06:30 PM
Highway8's Avatar
Registered RX8 Nut
Here is some more help.
Being in the Bay Area, you have a great wheel resource/vendor who is not far away (within an hour or 2) Rishie with AutoRND user name Endless Rotaries has a lot of knowledge about wheels, what will fit, what is and isn't a good value. Rishie has some of the best prices around and he takes care of the Rotary Community.
Old Oct 3, 2011 | 06:54 PM
RX8Soldier's Avatar
Time for boost...
I got my rims/tires of Rishie. Very satisfied
Old Oct 3, 2011 | 07:24 PM
tiltmode43's Avatar
OMGITM!
The lower the offset, the farther pushed out these are.
If you are looking for a direct bolt on fit, I would recommend around 18x9.5 ET45. Check out the Enkei RPF1 & NT03m. If you want similar design, though higher price tag, check out the Weds Sport TC105n. These XXR's are a more aggressive fit than what you are looking for.
Rishie @ Auto RnD can take care of you.
Old Oct 4, 2011 | 10:28 PM
+1 for Rishie... he'll get you all sorted out
UHATEIT
Dec 10, 2015 02:57 PM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
Brandonien
Jul 30, 2015 12:33 PM
AussieGray
Jul 16, 2015 03:58 AM
