Interesting article re: fuel and oil additives incl ZDDP
Old Sep 15, 2011 | 09:46 AM
HiFlite999's Avatar
For the technically inclined, surf the references in this article further:
http://www.thetruthaboutcars.com/201...tives-part-ii/
Old Sep 15, 2011 | 10:01 AM
paimon.soror's Avatar
Interesting, i use 1oz fp+ with every fillup ... figure it can't hurt, and you honestly can't trust the garbage in todays gasoline
Old Sep 15, 2011 | 10:02 AM
Well, that should explain why modern cars don't seem to last as long as cars made in the 80s 90s ...
Go green! More break downs, more new cars! Yay
It also proofs that we should premixed whenever we could ...
Old Sep 15, 2011 | 10:41 AM
Hmmmm.
Old Sep 15, 2011 | 11:15 AM
Roidz's Avatar
Strength/Confidence
Interesting indeed.
Old Sep 15, 2011 | 11:27 AM
HiFlite999's Avatar
I don't have conclusive factiods wrt reduced engine life, but will say in my rather extensive automotive grapevine, I've yet to hear of even one fuel injector failure. However, most injectors on the road today run at much lower pressures than new common rail gas/diesel systems, so the new ones may run into trouble much earlier.
This article does make me at least feel better about my premix though!
Old Sep 15, 2011 | 11:46 AM
Yeah premix is key but it has me thinking about using Lucas UCL again.
Old Sep 15, 2011 | 05:22 PM
dynamho's Avatar
I use Lucas UCL every 5 fill ups on all my cars.
I've never contemplated the combined effects of premix and Lucas. I didn't even try because I'm not well versed in chemistry. Yet I still wonder if combining them is additive in effect or if they mix to become something else...
Old Sep 16, 2011 | 02:19 PM
fyrstormer's Avatar
2009 RX-8 Touring
I just use Group 5 motor oil, which has polar molecules that stick to metal surfaces better than older oils. Should be fine without pre-mixing -- though I do have an S2 engine, so my lube system isn't borked from the factory. That helps a lot too.
EDIT: Notably, Group 5 motor oil has exposed sulfur molecules on the ends of the molecular chains, which I suspect may help make up for the lower sulfur content in the gasoline. In any event, though, gasoline isn't supposed to do anything except burn, and burn as cleanly as possible, so if there's trouble with premature wear in engines then the engines need to be redesigned. There are lots of metal coatings available that can greatly reduce wear.
drebbrnator
Dec 27, 2018 07:02 PM
IB Cristina
West RX-8 Forum
Aug 20, 2015 08:52 PM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
