Sergioo915
09-07-2011, 02:42 AM
So, looking at some of the post regarding the low idle and vibration issues surrounding RX8, I was wondering if there was a way to control or adjust the position on the throttle butterfly. The idea came from feeling how good and smooth my 8 idles at about 900-950 rpms. My 8 idles pretty good with some vibrations, which can be anoyning. While reving the 8, I noticed it was smooth and nice at about 900-950.
So i found this unit on Ebay for about 110$. It comes from Japan and is all plug and play 176670
I installed this unit on the radio face plate with very little effort.
176667
With double sided tape, I attached the controller box inside the radio unit and guided the wiring throught the channel
176668
Plug the harness to the pedal and connect to OBD II port, done.
176669
So after programing the unit, I found out that the position on the butterfly connot be ajusted. This unit has preset settings that are NORM, SPORT 1-7 and ECON 1-7.
which I found to be useful in actually changing driving characteristics of the throttle reponse. In Econ mod I got a 1-3 mile per gallon increase. Not bad.
On the Sport Mode, the fuel inconomy sucked, but the responce on the throttle during agrresive turning and accelaration was pretty inpressive. On normal Mode, well its normal. Has a safety feature for while car is in reverse (RED and Yellow wire in the driver running board)
On a lighter note. my car is idleing a little higher. I think its just the nature of the unit reading the data from the CAN bus
176666
Again, your thoughts and comments.
176667
176668
176669
176666
