How to: Connect your Access tuner RACE software for live tuning and DASHBOARD.
Old Jul 31, 2011 | 11:32 AM
lastphaseofthis's Avatar
Release the twins.
So someone ask'd. and i said i would get back with them when i got it working...
First. the PHYSICAL connection....
You need to connect your laptop's usb, to the USB cable that goes to the AP dongle. YOU SKIP THE ACCESSPORT. LAPTOP>cable>dongle>car.
YOU MUST be using the latest version of firmware.. when you connect the USB, it should install it automatically as long as you have all your accessport drivers on the pc.
Then, you hit ecu live-tuning, and it will attempt to connect. mine connected instantly and the green light came on at the bottom.
I first tried this using 2 usb cables and the accessport... it doesn't work like that, its much simpler.
Shortly thereafter my battery low light came on, so i didn't get to play around with live tracing...
NOTE: Live tuning does work on our PCM, as said below.. V ..
More information can be found in the accesstunerRACE PDF.
Old Jul 31, 2011 | 11:56 AM
NgoRX8's Avatar
Just so you know, you cannot do actual real-time tuning on our cars. Our PCM does not support it. Connecting ATR to the car is basically for dashboard and datalogging.
Old Jul 31, 2011 | 12:18 PM
Release the twins.
Gay.
Old Jul 31, 2011 | 12:26 PM
Originally Posted by lastphaseofthis
Gay.
http://www.youtube.com/watch?v=svwGRJA28lY
NgoRX8's Avatar
Gay.
Yes... yes it is.
Old Jul 31, 2011 | 12:39 PM
Release the twins.
Originally Posted by TeamRX8
"video"
yeah yeah yeah.. i got excited for about a min there.
Old Aug 1, 2011 | 10:17 PM
TechnoPsycho87's Avatar
Finally own one :)
Nice, but this doesn't apply at all to an Version 2B Accessport though, My OBD-II cable has a serial type connector, not usb. The OBD-II cable on mine has to plug into the AP. I have started from scratch twice with software and drivers and followed the atr faq pdf.
Old Aug 2, 2011 | 09:43 AM
Release the twins.
A. get a laptop with a serial.
OR
B. get a newer AP that uses USB.
Old Aug 2, 2011 | 09:49 AM
^ It's not a serial connector. But I am glad I have the older style. I found out the new style won't work for datalogging on the laptop because I was working on Hoss-05's car and he has the newer AP.
Old Aug 2, 2011 | 11:03 AM
NgoRX8's Avatar
Go try this...
Connect computer to AccessPORT via supplied USB to USB Mini Type-B cable, then AccessPORT to OBD-II via supplied OBD-II to 9-pin, black cable. All communications will pass from the computer to the vehicle through the AccessPORT.
Old Aug 2, 2011 | 11:16 AM
TX
Go try this...
Hmmm, never thought of that. Thanks bro. Hoss-05 and I have a netbook just for the cars, it's much easier than downloading the logs.
Old Aug 2, 2011 | 11:23 AM
NgoRX8's Avatar
I do the same. Plus it can log at 10 Hz regardless of the number of parameters we choose to log.
Old Aug 2, 2011 | 01:18 PM
MazdaManiac's Avatar
It does actually work like that on the current firmware.
If you have the newer version of the AccessPORT without a discreet dongle, pass-through is the only way to do it and it does definitely work in both PRO and ATR.
Where people run into problems is when they are trying to load a locked calibration for logging.
Old Aug 2, 2011 | 07:38 PM
Finally own one :)
Go try this...
That is the way i use it, ap says connected when i click connect to ecu but i get a cant find ecu, tried from main menu and in monitoring mode on the ap with no luck. And no, my tune is not locked. and my map is loaded in atr when i try as well
Old Aug 2, 2011 | 07:40 PM
CTRL-L then CTRL-B
You must have the newest AP drivers installed.
Old Aug 2, 2011 | 08:53 PM
Cool, good to know. Thanks.
Old Aug 4, 2011 | 05:43 PM
Finally own one :)
Well I am clicking on the equivalent of those shortcuts so there must be something wrong with the drivers. I have tried downloading all the drivers off the cobb site, i have tried just what atr installs and I also tried atr plus the dongle driver from the site. I used ap manager 2.0 in all 3 attempts. Am I missing an ap 2b specific driver or something?
Old Nov 11, 2011 | 08:49 PM
Finally own one :)
Just a update, thinking it was windows on mac screwing it up, i tried it on a windows 7 tablet i got a few days ago, exact same problem. installed atr, manager, updater and then dongle driver, downloaded the map off the ap. opened atr, loaded map. connect to ecu, instant error can't connect to ecu, and the ap says connected to pc when it errors. Any hints would be helpful. Thanks. 2006 GT with a AP 2b
Old Nov 11, 2011 | 09:01 PM
The updater is now part of the APManager, so if you did a separate install, you are either using the wrong versions of the software or you wrote over the correct driver with the outdated updater software.
Old Nov 12, 2011 | 06:26 AM
When you connect to the computer or car it takes several minutes for the software to connect and communicate. If you attempt to use it prior to this process completing you will get those errors. The ignition key has to be in the full on position as well during this process. Also the dongles are not the best on these and sometimes you have to play around twisting or manipulating it such that all the pins connect. There is a thread on the forum where a member thickened all the dongle pins using solder to solve this problem.
Old Nov 12, 2011 | 09:48 AM
No it doesn't. It is instant.
The old dongle had this problem. The newest does not.
The problem is often in the DLC. When I started to get connection errors, I took a good look at the DLC and the pins had all spread.
I just pinched them down a bit with a jeweler's screwdriver and now it is always perfect.
Old Nov 12, 2011 | 12:32 PM
Originally Posted by MazdaManiac
No it doesn't.
yes it does, on mine and the several others I've had in my possession, on different computers too. Just because we have a different experience doesn't make it so.
Old Nov 12, 2011 | 01:04 PM
Uh, exactly.
If you are experiencing that sort of connectivity issue, you are in the minority.
Old Nov 12, 2011 | 02:27 PM
More than likely we are both in the majority with a communication issue ....
Old Nov 12, 2011 | 03:57 PM
Well, PROTuner aside, I have experience with about 60 RACETuner clients directly, none of which have this issue.
I've supported over a hundred Cobb clients with RACETuner with only a handful that had connection issues and it was always either software/driver conflicts or dongle connection issues, both of which I've already explained away.
So, you are a bit of Mrs. Slocombe if you believe yourself to be in a majority.
