having problems installing a motor in my 04 rx8
Old Jul 19, 2011 | 11:29 PM
james coleman's Avatar
i got the motor in and almost got it hooked up but can anyone tell me where the vacuum hose on the throttle body goes?not the three on the air intake but the one on the throttle body itself?
Old Jul 19, 2011 | 11:40 PM
That is a coolant fitting....from the back passenger corner of the rear iron...to the lower rad connection area by the OMP
Old Jul 20, 2011 | 12:03 AM
If you thought that was a vacuum line then I suggest looking at an FSM just to make sure you have everything hooked up right before you fire it up.
Old Jul 21, 2011 | 07:34 AM
Water into intake, that sounds fun.
Old Jul 22, 2011 | 11:34 AM
CyberPitz's Avatar
Huge hole is huge
That's the Mr. Fusion connection! Don't forget that, or you'll require a LOT of plutonium for that Flux Capacitor.
rotorocks
47
May 11, 2016 03:23 PM
Sifu
Aug 30, 2015 10:51 PM
MauiMazda2
Aug 3, 2015 02:47 PM
Belalnabi
Jul 17, 2015 07:48 PM
