Stupid AccessTuner trick 0x10
Old Jun 24, 2011 | 07:09 AM
oltmann's Avatar
I raised my redline. It is actually:
42534646828009991000000000000000000000
But the interface truncates at the 7th digit.
Even if I only make 1lbft of torque, I will have 8 decillion horsepower. Beat that.
Old Jun 27, 2011 | 02:17 AM
oltmann's Avatar
Guess what happens when you set this table like so...
That's right! Nothing! At least as far as I can tell. WTF does that table do?!?!
Old Jun 27, 2011 | 02:27 AM
Flashwing's Avatar
3-wheeler
Exactly what it says. Sets your closed loop air/fuel targets based on RPM and load.
Old Jun 27, 2011 | 03:16 AM
oltmann's Avatar
Can you expand on that? As I said, I've yet to find any value which has an effect. 2005 Federal ROM.
Edit: What really puzzles me is that there are at least four CL maps that Cobb did not include.
Code:
 0x3FA3D70A
ROM:00070800                     .long 0x4023D70A, 0x4075C28F, 0x40A3D70A, 0x40CCCCCD, 0x40F5C28F
ROM:00070800                     .long 0x410F5C28, 0x4123D70A, 0x41A3D70A, 0x41F5C28F, 0x4223D70A
ROM:00070800                     .long 0x424CCCCD, 0x4275C28F, 0x44480000, 0x44C80000, 0x45160000
ROM:00070800                     .long 0x45480000, 0x457A0000, 0x45960000, 0x45AF0000, 0x27742774
ROM:00070800                     .long 0x27742774, 0x27742774, 0x27742774, 0x27742774, 0x27742774
ROM:00070800                     .long 0x27742774, 0x27742774, 0x27742774, 0x27742774, 0x2774FFFF
Old Jun 27, 2011 | 08:40 AM
Even if I only make 1lbft of torque, I will have 8 decillion engine pieces. Beat that.
f1x3d
Old Jun 27, 2011 | 05:45 PM
oltmann's Avatar
You spell funny.
Anyhow, I've become concerned that something is up with closed loop that I can't measure, so I'm setting it all back to stock until I can measure the p/w of each injector on a scope.
Old Jul 1, 2011 | 04:22 AM
oltmann's Avatar
Okay, I figured out how to do something halfway useful with that table. Now I'm really curious wrt what the original purpose of it was. Full-time closed loop?
Old Jul 1, 2011 | 04:17 PM
oltmann's Avatar
Has anyone ever tried running closed loop full time?
I made a tune that way out of curiosity. I had to lower my maf scale and fatten the fuel injectors to force my load values under 100. Seems to always exit closed loop at 100 load.
Used that stupid closed loop b table to get more granularity from 5000-9500 rpm.
Closed loop feedback only assumes partial command while accelerating, I guess based on the RPM delta thingy.
So far, it is okay. I'm really curious to see if LTFTs improve things. My only concern is that the load calculation may use air temp or baro somehow, and that "lying" to the ecu about the mass of the air may cause unforeseen problems.
Old Jul 1, 2011 | 06:31 PM
MazdaManiac's Avatar
Yes. I've built two completely different calibrations on two NA cars and (in a limited way) a calibration for my own turbo application.
It is, to say the least, "interesting", but I couldn't see why I should bother since I could produce the exact same results using Mazda's closed-loop constraints with regards to target lambda and transition.
I wasn't convinced that closed loop could be done safely in boost and several high-profile tuners have lost several high-profile engines over the last two years trying it, so I can't be bothered with an intellectual exercise of that scale that doesn't have any tangible benefit.
Old Jul 1, 2011 | 07:36 PM
oltmann's Avatar
Seems like lots of the standalone systems do it, Perhaps either to allow their autotune features to work at WOT or just to add a bullet point to the feature list.
Also, lots of slow cars with stock widebands (ex Saturns.) If it is safe for slow cars, I should be okay.
I'm just hoping that after the ltfts set up they may help me see some problems, or fix some oddball load points in the ve table.
Old Jul 1, 2011 | 09:22 PM
as long as everything is in spec you will likely be fine, but as soon as the main O2 sensor goes off etc you can lose an engine real quick, fixed open loop programming during high load conditions is generally considered less risky overall
Old Jul 2, 2011 | 01:25 PM
oltmann's Avatar
Yeah, though it isn't clear to me that STFTs get their normal 25% correction while accelerating, I can see how even a 5% "false" lean correction would kill some motors real quick, especially if compounded with concurrent fueling errors.
Old Jul 2, 2011 | 01:33 PM
Are you saying that you typically see lots of trim when you are in transition or are you commenting on STFT's efficacy in a pure closed-loop environment?
Just as an aside - the tune that I run on my car (which has an airflow delta that is way more than 200% of the OE calculation) has absolutely no LTFT and never sees more than 4% STFT in any situation.
I have dead-on 14.3 - 14.5 AFR in all load situations below 70%, regardless of OL or CL and a smooth progression to 11.2:1 from there to 95%.
I haven't reflashed my own PCM since February.
Old Jul 3, 2011 | 01:22 PM
oltmann's Avatar
It just seems to me that it takes a some time for O2 feedback to apply it's full correction, and so when rpm is changing more quickly, it has a smaller effect. As usual, I could be mistaken.
But, yes, I do get more STFT in transition, guess I need to work on that, though I haven't had any LTFTs develop on this calibration yet in 75 miles or so. I was thinking I had accidentally disabled them somehow, haven't driven more than 15 miles on a tune since I started... Been kinda manic about it.
Since you mentioned it, I was looking at a map in the rom, big 19x26, appears to be load vs rpm. It seems to flatten out at high loads, in a shape roughly conforming to peak load. I know you probably won't tell me what it is, just wondering if people with > 190 load had to recalibrate it since I'll probably never be in that situation, it is just so interesting-looking.
Last edited by oltmann; Jul 3, 2011 at 01:25 PM. Reason: too many typos to leave be
Old Jul 3, 2011 | 02:27 PM
The correction is nearly instantaneous - by the next combustion event.
The actual feedback time can be two or three combustion cycles (or even longer, depending on sensor placement and flow restrictions, reversion, etc.).
It isn't any less accurate than you would be trying to set calculation adjustments by looking at them on the dyno and that is really what fill-time CL would be doing - creating a correction for future excursions into a given load cell (not correcting for current conditions).
You have to put hundreds of miles in all driving conditions to really see what a calibration change does to the overall engine response.
That is probably the Ve table. It is an fuel correction table. Though, IIRC, it is 20x19 (not including the reference rows/columns).
Old Jul 3, 2011 | 02:57 PM
oltmann's Avatar
I think I found the VE table a while ago, it is this other one that I never noticed until I downloaded a trial of ecuEdit and had it scan the map offset table. ecuEdits algorithm isn't perfect at this, but this one certainly looks like a real map.
I don't have the hardware to try to play with it, and I haven't even tried to see where it gets referenced yet.
Attached Thumbnails Stupid AccessTuner trick 0x10-vetable.png   Stupid AccessTuner trick 0x10-question.png
Old Jul 3, 2011 | 03:09 PM
That looks a lot like one of the oil metering tables.
I'll pop back into ECUedit again and compare.
Old Jul 3, 2011 | 03:22 PM
oltmann's Avatar
Starts at 0x687B0 in the ROM I'm looking at now, basically at the end of the map section.
Old Jul 3, 2011 | 04:17 PM
Brettus's Avatar
Boosted Kiwi
Impressive . Why do you feel the need to reach 11.2 that early in load ?
Old Jul 3, 2011 | 07:08 PM
Because detonation is caused by hitting that point later (for fairly complex reasons).
You want to be at your target boosted AFR before you hit more than 100% load.
I am around 13:1 at 85%, so that isn't really "early" by any stretch of the imagination, anyway.
The real trick is the high-load fueling below 4000 RPM. There is a bit of a trick to get that right.
Learners_Permit
Sep 27, 2015 07:38 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
thegoodfella334
Sep 2, 2015 09:57 AM
wanted797
Aug 26, 2015 11:24 PM
Love_Hounds
Jul 23, 2015 12:44 PM
