A Few Questions Regarding how you Drive..
Old Feb 27, 2004 | 12:37 PM
RenesisRotary's Avatar
1) Whats your Avergage Speed on the Highway/Regular Roads?..
2) What RPM Do you shift at? And in what gear (For both regular, and "Spirited" driving)
3)Do you leave DCS on All the time?
4)What is the Average RPM you drive at on the highway/Regular Roads?
5) What PSI do you keep you're tires at?
Old Feb 27, 2004 | 12:55 PM
epitrochoid's Avatar
Riot Controller
1. surface roads 50-60. highway 85-100
2. regular: 3500. spirited: 8500
3. only in the rain and when im not getting on it
4. surface roads ~3k. Highway between 4-5k
5. factory set 32 psi
Old Feb 27, 2004 | 01:05 PM
winter's Avatar
1. Regular roads, within 5mph of posted speed limit. Freeway, about 90.
2. Usually shift between 5 and 7k, unless I'm putting it into 6th to cruise.
3. For now, yes.
4. Between 4 and 5k.
5. 34psi
Old Feb 27, 2004 | 07:08 PM
P Daddy's Avatar
1. Usually about 20 over the speed limit.
2. normal 4-5 spirited 8-9
3. leave it on unless I'm just having fun
4. Around 4
5. 32 PSI
Old Feb 27, 2004 | 07:12 PM
RX8_GT's Avatar
1) 5-8 mph more than speed limit
2) about 4000 - normal - 6000 spirited
3) 99%
4) see 1
5) 32
Old Mar 1, 2004 | 04:02 PM
Trx8's Avatar
Is Scarce
(1) Depends what other traffic is doing, try < 10 MPH over limit
(2) Shift before 3500 unless I am out for performance
(3) Yes, DCS on
(4) Less than 3500 (AT, 3500 RPM is > 80 MPH)
(5) 32 PSI
Old Mar 1, 2004 | 06:58 PM
SpacerX's Avatar
Pro Audentius
1. Within 5-10 mph of the posted speed limit.
2. Am breaking in the engine right now. Have not been taking the engine past 3.5k normally, but occasionally up to 6-8k. I will probably maintain the practice of shifting at 3.5k for most running about.
3. If it's not raining, I turn it off... usually -- when I remember to turn it off.:D
4. Varies with speed, but I work up to 6th as a general rule, if I'll be cruising for a while (e.g., 6th gear + 75mph = 3750rpm)
5. For now, factory spec -- 32psi
Old Mar 2, 2004 | 12:03 AM
khoney's Avatar
FX8TED on my RX-8
75/45
>6000 whenever possible, always do 1st and 2nd.
Yes
3800/2500
32
Old Mar 7, 2004 | 08:17 AM
MadMacz's Avatar
1. Local roads - just over the limit (lotsa cops round here) Hyway - 75 to 95+
2. Between 3500 and 4000 - still breaking the engine in.
3. Yes
4. around 3500
5. 32 PSI
Old Mar 7, 2004 | 09:32 AM
tpryor's Avatar
Re: A Few Questions Regarding how you Drive..
1) 80-85 Highway, 50-60 on surface streets (20-25 in housing areas)
2) Typically, around 6000
3) No
4) 4000 is my "chosen" cruise RPM. I'll put it into whatever gear gets me closes to this.
5) 36
Old Mar 7, 2004 | 09:45 AM
MazdaManiac's Avatar
1) Whatever feels good. Anywhere from the speed limit to 20 MPH over. I hit 100+ on the highway if I can.
2) 5k or so for "regular" driving, 7k to redline for everything else.
3) I turn it off all the time unless it is particularly wet.
4) 4k
5) 32 PSI
Old Mar 20, 2004 | 11:43 AM
JoeRX8ter's Avatar
1) Regular roads 55-60. Highway 80 to100
2) 5-6K around town. 7.5-9K horsing around town
3) Off in good weather
4) 4K
5) 32 PSI, checked once a week
Old Mar 20, 2004 | 02:11 PM
DemonRX-8's Avatar
I got nothing good to say
1. Anywhere from 10-20 mph over the posted limit on most roads. The speed comes so easily in this car!
2. Usually shift at 5-7k, depending on my mood. Redline for max acceleration runs. I usually shift straight from 4th to 6th since 4th gear will get me well above the posted speed limit anywhere in the country - then click into 6th for steady state cruising.
3. DCS off 99% of the time, unless the roads are very slick.
4. I cruise in 6th gear as much as possible whether on the hwy or off (anything above say 45 mph), so it would be whatever rpm it's turning at the speed I'm driving.
5. Tires set at factory pressure. That reminds me that I need to check them.
Old Mar 20, 2004 | 04:19 PM
MBL-RX8's Avatar
1. Regular roads, 5-10 above limit. Highway, 15-20 above limit.
2. Normally, 4-6k rpm. Otherwise the sky's the limit *BEEEP!* :D
3. Waiting until weather warms up before going DSC-less.
4. I shoot for 3-4k rpm, sometimes 1-2k if traffic sucks.
5. Factory 32psi.
Old Mar 21, 2004 | 08:13 AM
Psylence's Avatar
Back in the family
1. 15mph above the limit on all roads except highway. Highway, 20-50mph above limit.
2. Normal: 4-6k. Spirited? BEEP!
3. DSC is off unless there is a lot of rain.
4. 3-5k. Higher end is on the highway of course. Anyone for a taller 6th?
5. 34 for now, will be expermenting with pressures in spring when these rancid stock tires are gone.
Old Mar 21, 2004 | 09:02 AM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
1. 40-50 city and 60-75 highway
2. It's an automatic!
3. Yes.
4. See answer to #2.
5. 32 psi.
Old Mar 21, 2004 | 09:23 AM
Unser's Avatar
1. Av. Spd: 8mph over speed limit, cruise control on all the time
2.Shift RPM: 9000 in 1st, the if speed limit is not reached 9000 in 2nd, then cruise control at 8 over speed limit
3. DCS on all the time, on curves I love the 1.0 sec slip and auto control and the flashing light in the middle of the RPM conter before every shift
4. Av. RPM:highest gear possible when cruising as long as RPM is over 2500
5. 32psi, 4 tires inflated at once so pressure is 32 cold.
Old Mar 21, 2004 | 10:31 AM
Elara's Avatar
1) Whats your Average Speed on the Highway/Regular Roads?..
75-80, highway, 55-60 normal roads
If I'm trying to get good gas mileage, 3-3.5k rpms. Most of the time(spirited, I guess), 5-6k, with a redline a day, usually in second as I launch myself onto the highway.
Usually, unless I'm trying to have fun with the car on corners
As low as I can keep it- normal roads, say 2500-3000. Highway it's usually hovering at 4k rpms
32
Old Mar 21, 2004 | 10:43 AM
Ajax's Avatar
1) 5-10 over when I'm paying attention to it.
2) 3500-6000. I'm still in the break in so I try to keep it lower than normal.
3) Until I get used to the car, yes.
4) <3750 (trying to save gas and learn the feel for the car)
5) Factory
Old Mar 21, 2004 | 12:20 PM
loco4rx8's Avatar
BSG 75
1) 60-65 mph
2) Regular: 4000 Spirited: 9000
3) Yes
4) 3000-3500
5) 32
Old Mar 21, 2004 | 01:39 PM
chief8's Avatar
1)within 5mph city, within 15mph highway
2)5-6k normal 7-9k spirited
3)Always off..Car has better feel and gas mileage is much better
4)3000-3500
5)32psi
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
