What was done to my car?
Old Jun 13, 2011 | 02:50 PM
Reaver's Avatar
So I purchased an 04 rx8 a few days ago and I absolutely love it! However, there has obviously been some modifications to the car that I have very little idea what they are. Perhaps just as important if not more so than figuring out what it is, is actually the question of how do I fix it? And when I say fix I mean that loosely because everything works as it should in the car, but either a) how would I return the car to stock or b) how would I utilize the connections and wiring already made?
You can see in the pictures, there's a couple pictures from the trunk of the car, I haven't a clue of what any of this is other than the obvious usb plug, and I know that one connection is an older PC connection I believe I've seen used to connect monitors.
http://postimage.org/image/9a21agh0/
http://postimage.org/image/9ap6tbdw/
here you can see where one of the connections ends up, the rear seat console of the car:
http://postimage.org/image/9ashw0dg/
and finally here is the dash, I don't even know where to begin with this plastic piece..it pops out if i pull on it a bit but otherwise it fits surprisingly well, however when I pull it out its pretty obvious he did this freehand because it's not a perfect shape or anything like that...
http://postimage.org/image/9b919hb8/
http://postimage.org/image/9bhay7s4/
and here it is with that plastic piece out:
and this is the plug that is in there, there might have been another plug in there but i didnt look thoroughly...
http://postimage.org/image/9c2sxq78/
So I don't really know much about this sort of thing but has he done the hard work to get some sort of carputer going in my car or something similar? Your help is greatly appreciated!
Old Jun 13, 2011 | 02:56 PM
Looks like a car PC setup to me. post some pics of your car, maybe they were a member here at some point.
Old Jun 13, 2011 | 02:57 PM
Reaver's Avatar
Oh I'd rather not hehe...it has a primered bumper and a crappy CF hood on it, it needs to be sanded, a little bit of bondo and painted. I could do a shot from the driver side if you really want to see it :p
Old Jun 13, 2011 | 06:34 PM
firebirdude's Avatar
User and Abuser
CarPC for sure. Has he done all the hard work for you? Eh not really. You'd have about the same amount of work ahead even if you were going right from stock. The connections in the trunk are a VGA monitor cable, USB cable, and headphone minijack. Nothing special. Looks like S-video up in the dash. Nothing special. He probably had a cheap monitor with built-in stand placed up there.
Looks like he took the wires he needed with him. No power ran to the rear PC area. No power ran to the front dash. They probably had special connectors on the wires, so he needed to take them.
So what problems are you having? Nothing? Tape up the exposed wires at the Bose amp and let er eat. Doesn't look like you have to do anything to get it back to stock. Remove the wires if you want.
Old Jun 13, 2011 | 06:42 PM
Reaver's Avatar
Well, what solutions do i have for that plastic piece on the dash, it just sits up and is sort of distracting.
Old Jun 13, 2011 | 06:47 PM
User and Abuser
Replace the dash hood with a factory one, one that holds gauges, or just cover it up with a carpet dash cover.
Old Jun 13, 2011 | 07:59 PM
Reaver's Avatar
Thanks, an ebay search doesn't give any results so I guess I'll just lurk the for sale section on rx8club for a while.
Old Jun 13, 2011 | 08:44 PM
User and Abuser
http://cgi.ebay.com/ebaymotors/MAZDA...s#ht_500wt_975
http://cgi.ebay.com/ebaymotors/DASHM...ht_5875wt_1078
Old Jun 13, 2011 | 10:27 PM
Reaver's Avatar
Thank you sir, much appreciated. I guess my search was pretty crappy :x
Old Jun 13, 2011 | 11:05 PM
Any junk yard will have the top center piece, it's no biggie to replace. Check out www.mazmart.com, www.partsgroup.com, and www.revvinsevens.com.
Old Jun 13, 2011 | 11:34 PM
Reaver's Avatar
all bookmarked for future part searching, thanks !
Skyl3r
Dec 2, 2019 04:51 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
AussieGray
Jul 16, 2015 03:58 AM
