NW RX-8 Forum Serving WA, OR, ID, AK
Warranty help
Old Jun 7, 2011 | 07:37 PM
tunerwannab's Avatar
Warranty help
Of the local group who has used Milam Mazda? I'm taking my 8 in there tomorrow night as it is starting to feel tired. I had a compression test two years ago and it was borderline then I think. Any tips for talking to the service guys. Not much time left on my warranty as it was built in 03.
Also think they will give me trouble over my BHR coils? My car is an 04 with 76,000 on it.
Old Jun 7, 2011 | 07:52 PM
pdxhak's Avatar
Official Post Whore
They should not give you issues over the coils. If they do then engage BHR because they have dealt with dealerships that said their coils were an issue.
If the compression is still borderline then they will mostly likely pass the car. They may want to swap in new plugs and do a decarb to see if it helps. Also if your starter is old they will say you need to swap it.
Old Jun 7, 2011 | 08:10 PM
Thanks. I don't think my car has the updated starter.
Old Jun 7, 2011 | 08:13 PM
rotomaven's Avatar
more info on updated starter? my car seams to take forever to start
Old Jun 8, 2011 | 03:12 PM
pdxhak's Avatar
Official Post Whore
FWIW when my last motor was swapped the dealership said the motor would not be covered unless the starter was swapped.
Old Jun 8, 2011 | 06:15 PM
The dealer called and said there are indications of internal engine damage but they are required by Mazda to run certain tests. Cost is $300-$350 if it does not need a new engine.
He said it is an engine balance test, some toad test, and something called a baro test. He wasn't sure how the baro test was spelled.
This sound about the norm?
Old Jun 8, 2011 | 08:22 PM
hornbm's Avatar
I was under the impression that the only test they perform is a compression check. And how exactly do you perform an engine balance test? Or a baro test. And I'm guessing you meant load test? I'll let others chime in here, but that doesn't sound right.
Old Jun 8, 2011 | 10:04 PM
Road test not toad sorry. he said a "baro" test is like a compression test for a rotary.
Old Jun 9, 2011 | 12:51 AM
kristopher_d's Avatar
Drive Master
The baro test, or barometric test, is a replacement for the compression test because Mazda discontinued the electronic compression tester required for rotaries. It's essentially a vacuum test.
When they do the baro test, insist they do it with the cat disconnected. When I had Ruby in for what I had already determined was a bad cat, the dealer went down the new engine route until they pulled the cat and tested again. Strange thing about air pumps, you can pull more air in if you can't expell what's already there.
Yes, a new engine would probably be nice, but there are lots of opportunities for things to go wrong with a swap, even under warranty, so if your engine is actually good, and it's just a failing cat that is causing loss of power, that's the route you want to go down.
Old Jun 10, 2011 | 04:34 PM
They did a compression test and it failed. They did it for me a few years ago so I knew they at least used to have to tools. And the "road test" after poking he said " we have to drive it then we do a cleaning process then drive it again" to which I said " oh you mean the decarb cleaning". He then just agreed to do the compression test and hung up.
He then didnt call me back today so I called there and he told me it failed, they did the decarb after Mazda requested it so on their dime to start with and after the decarb they decided to order me an engine. I will take it back in a month or too to have the car checked also since I am near the 80k limit.
While they do the motor I'm going to get the new starter, some new plugs and BHR is going
To update some stuff on my coil kit! Should be running smooth soon. I hope.
Old Jun 10, 2011 | 07:16 PM
pdxhak's Avatar
Official Post Whore
Good deal! When I had my motor swapped I ordered the BHR ignition kit. They sent me the plugs ASAP so the dealership could use them to swap in. Ask your dealership about swapping the fuel line as well.
Old Jun 10, 2011 | 08:07 PM
I asked about a fuel line and the service writer wasn't sure what I was talking about. What fuel line is it exactly and why is it good to replace?
They showed me the compression results and they were 5.9,6.3, 6.2. Minimum should have been 6.9.
Old Jun 15, 2011 | 12:57 PM
dondo's Avatar
100% baller (finally!)
the fuel line pn is in kevin's renesis 2.0 thread. it's good to replace because others have reused it and the loose connector caused their cars to burn.
Old Jun 21, 2011 | 10:44 AM
Car is done I will pick it up today after work. I'm excited to see how quick it cranks and if it idles much smoother.
Old Jun 21, 2011 | 11:20 AM
pdxhak's Avatar
Official Post Whore
Good deal Hopefully it is running better than ever!
Old Jun 21, 2011 | 12:05 PM
dondo's Avatar
congrats!
Old Jun 21, 2011 | 04:33 PM
RearDriveNinja's Avatar
Wow, where is this dealership located? They managed to get your engine swapped and get the car back together in less time than it took mine to replace 3 gears in my tranny.
Old Jun 21, 2011 | 04:35 PM
Milam Mazda in puyallup. Tomorrow it would have been two weeks.
Old Jun 21, 2011 | 10:48 PM
Haven't driven much but much smoother and much quieter. Never really thought it was noisey until I got it back.
Old Jun 22, 2011 | 12:39 AM
ANIBALRX8's Avatar
Cool
Milan Mazda is Great, I remember went my check engine light came on and I lost power, I got them to look at it on the next Monday, they gave it back to me on tuesday and order the engine, by friday the call me to drop off the car on Monday and by wednesday I pick it up, and they did my front brakes too, at the same time!
Old Jun 22, 2011 | 01:14 AM
FazdaRX_8's Avatar
is the starter a warrenty thing? is there a way to tell if I have the new or older starter?
Old Jun 22, 2011 | 10:07 AM
EDZRIDE's Avatar
2005 White GT
Look at the starter label.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
duworm
Oct 1, 2015 04:57 PM
XianUnix
Sep 29, 2015 03:48 PM
