Mazda Engineers win SAE Outstanding Technical Paper Award for HCCI Paper
Old May 17, 2011 | 10:40 AM
zoom44's Avatar
http://finchannel.com/news_flash/Oil...ve_JSAE_Award/
The technical paper analyses the effects of different fuel components on ignition performance in a high-compression gasoline HCCI engine, and develops a theoretical model that predicts auto-ignition timing for the various grades of gasoline used in different markets. The paper also shows that, when the engine is operated with a standard spark ignition, the extra heat generated as the piston approaches top-dead-center does not increase the likelihood of knocking (abnormal combustion), enabling increased power output. Mazda's breakthrough SKYACTIV-G gasoline engine, which significantly improves fuel economy and torque thanks to the world's highest compression ratio of 14.0:1, utilizes the results of this analysis.
The award goes to
Takashi Youso, Powertrain Development Div., Mazda Motor Corporation
Masahisa Yamakawa, Powertrain Development Div., Mazda Motor Corporation
and also two co-authors from outside of Mazda
Shigeyuki Tanaka, Cosmo Oil Co., Ltd.
Jin Kusaka, Waseda University
I had read something else awhile ago that mentioned HCCI in connection with the Sky G. It seems like Sky G is an intermediate step to HCCI. Using some HCCI ideas while still utilizing a spark.
Old May 17, 2011 | 11:26 AM
HiFlite999's Avatar
Wow, this seems to fall into the really big deal category. Seems to me that removing NOx from the emission equation, one would then be free to run very lean mixtures which would be great from HCx and from an mpg standpoint.
Old May 17, 2011 | 12:49 PM
MattMPS's Avatar
Wiseguy
yes, Charlie. i've read too...Skyactiv engines are considered by Mazda the basis for future HCCI engines (read in official interview with some engineer)
If you note Japan automotive industry seem not keen to use a massive downsizing with turbo in gasoline engines..
in that interview the Mazda engineer said that is not easy to obtain an HCCI engine from a small displacement+turbo engine....
Old May 17, 2011 | 01:42 PM
too bad we (in the states) will only be getting 13.5:1 compression, why? our gas has garbage in it (Ethanol)
Old May 17, 2011 | 01:48 PM
kvndoom's Avatar
The Slow and the Serious
Not ****! Energy!
Old May 17, 2011 | 02:18 PM
zoom44's Avatar
and that is exactly, in part, what their work addresses
Old May 17, 2011 | 02:20 PM
zoom44's Avatar
right, that's it. it was in one of the recent videos too, same quote.
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
Rx808BI
Aug 9, 2015 10:06 AM
Belalnabi
Jul 17, 2015 07:48 PM
