View Full Version : Diy battery relocation to Washer fluid
pyropal188
05-08-2011, 10:35 PM
With out going into to much detail, i wanted to lighten my battery weight and free up some room behind the radiator for better air flow. so i decided to made a custom plate to mount the battery, a voltmeter and a 100 amp circuit breaker were the washer fluid bottle would be located. i know this isn't a "ground breaking idea", i just wanted to add my own components to the setup.
i as able to use the original ground and positive lead from the starter motor. i did have to rewire the EPS power,rewire the power to the main fuse box and shorten up the alternator wire.
- $18.48 3-1/2 Digital Blue LED DC 2V 20V Meter (8135) http://www.lightobject.com/3-12-Digital-Blue-LED-DC-2V-20V-Meter-8135-P219.aspx#
(if i did it again i would buy the mini on instead) http://www.lightobject.com/3-digit-Mini-Blue-LED-DC-100V-Volt-Meter-P328.aspx
- $170 Braille Battery B2015C 15 lbs 1067 PCA 6.8" x 3.4" x 6.1" Carbon Racing Battery www.autopartsdealer.com (on sale)
- $42 100 amp maribe Circut breaker (can probably find cheaper)
http://order.waytekwire.com/products2/M50/140/200/400/1/Hi%20Amp%20Surface%20Mount%20Man.%20Trip/Circuit%20Breaker%20High%20Amp/Circuit%20Protection/
-1/4 inch aluminum plate i had lying around at work.you can buy from mcmaster Carr or maybe your local scrap dealer will have misc aluminum plates you can purchase and cut up.
-Time to make plate and hold down arms-Priceless
The first picture is my original design that i later scrapped.
pyropal188
05-08-2011, 10:37 PM
more pics of the unfinished wiring mess
dmedz8
05-08-2011, 10:41 PM
what was the price of everything? do you have any links?
paimon.soror
05-08-2011, 10:46 PM
I like!!! +1 on pricing and links
rx8_504
05-08-2011, 10:58 PM
Nice set up dude
monchie
05-09-2011, 01:23 AM
No problem or issues with the swap?
RX8Soldier
05-09-2011, 09:22 AM
I like this. I just wish I lived in an environment where I didn't need my window washer so often... :(
pyropal188
05-09-2011, 06:05 PM
No problems at all. Actually runs better because i added extra grounds. there is a body ground and engine ground conveniently located right next to new location of the battery.
I figured the most i use the washer fuid is in the winter time, with all the salt they use in Illinois. but i dont drive in the winter anymore. and since my car is so thirsty i just clean the window every time i fill up.
pyropal188
05-09-2011, 06:16 PM
Final product
paimon.soror
05-09-2011, 06:36 PM
So are you going to market this bracket??? Count me in if you are, thats freakin sexy!
jskup1
05-09-2011, 06:39 PM
Wanna sell your clear winshield washer tank?
dmedz8
05-09-2011, 06:59 PM
+1:naughty:
rx8_504
05-09-2011, 08:13 PM
I wouldnt mind buying a bracket of you, if you decide to fab some more...its good to free up some space for the radiator and makes it easier then relocating the battery to the trunk
paimon.soror
05-09-2011, 08:57 PM
i hear a group buy ;)
TeamRX8
05-09-2011, 10:21 PM
you might want to wait and see how long that battery lasts in the engine bay heat first ...
dmedz8
05-09-2011, 11:54 PM
uh oh...:scared:
stinksause
05-10-2011, 12:30 AM
teamrx8 is always the party police ...
pyropal188
05-10-2011, 12:50 PM
are you suggesting i mount it in th trunk?
pyropal188
05-10-2011, 12:54 PM
i will consider making a few more if i have time
Grimm0ne
05-11-2011, 08:36 PM
I like the idea, but as TeamRx8 said, heat as thats the side with the most heat (lazer temp gun for the win).
I would do the whole setup, but for some reason, that empty space seems off in your picture, i would need to put something there or fab a cover..
but mad props for the build.
pyropal188
05-12-2011, 11:45 AM
I am a little concerned about the heat from the exhaust being so close to the battery.
Will this work? if i enclose the battery in a box. make a few holes in the box on the passenger side of the box and vent the box to the negative air pressure being created by the gap between the hood and the windshield? it would pull in the air through the holes and vent by the hood.
shadycrew31
05-15-2011, 01:30 PM
My only issue with having the battery in the trunk is that I bought my car with a valet key only :(. If the battery ever died it would be a pain in the ass to get it open.
No idea where the actual keys for the car are the dealer said if they found them they would forward it to me.
So if you find a nifty solution to keep the battery cool please let me know!!
paimon.soror
05-15-2011, 02:26 PM
Just throwing ideas out there, but if you want to keep that location, maybe you could fab up some sort of duct from aluminum panels?
http://www.rx8club.com/attachment.php?attachmentid=172025&stc=1&d=1305487668
you can maybe see where I am going with this, but have some "ram air" type venting lead to the battery. Again, just throwing ideas out there.
