Removing touch up paint/clear coat
Old Apr 24, 2011 | 05:54 PM
Rotary-RX8's Avatar
Girls who drive stick FTW
Is there anything that will remove previously put on touch up paint and its clear coat ?? Last year i touched up my paint chips with the mazda pen that has the paint on one end and the clear coat on the other. Big mistake !!!1 I put the clear coat and you can see the touch up clear coat. Im trying to remove any previous touch up work so i can re touch up everything and use langka. Ive tried paint thinner... nothing. So is there anything that will for sure remove previous put on touch up paint and its clear coat
Old Apr 26, 2011 | 08:44 PM
Rotary-RX8's Avatar
bump. Im thinking sandpaper a very fine grit maybe 2000 will remove the touched up clear coat
Old May 2, 2011 | 09:50 AM
Brettly2005's Avatar
Brett Cov
Use a 2000 grit paper first, do a couple strokes with a block sander and some water. then go over that again with 3000 grit. make sure to wet the sand paper as well. me and my friend just started up a mini detailing company on the side. heres the result after doing this to my 8. (I also used my 3 step 6 speed buffer afterwards)
top is buffed, bottom is not
after it all
Old May 2, 2011 | 08:37 PM
Rotary-RX8's Avatar
Thanks !!! Thats what i was thinking of doing but with soapy water lol.
Old May 3, 2011 | 02:42 AM
Brett Cov
I dont see why that wouldnt work! Just be careful. Dont over do the strokes though, or else youll cut through the clear coat.
Old May 3, 2011 | 02:45 AM
Brett Cov
And make sure you compound, polish, and wax afterwards.
Old May 3, 2011 | 08:14 AM
Rotary-RX8's Avatar
^ Yup of course. See right now im trying to get my car in perfect condition before i polish and wax. So that means any touch up and any dent removal before i do the full out spring detail Thanks brother.
Old May 4, 2011 | 09:56 AM
Brett Cov
That's how I was too. no problem. Happy spring cleaning
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
GK1707
Sep 27, 2015 07:33 PM
