Boosted 8 Running too Rich (w/ AP)
Old Apr 7, 2011 | 10:49 AM
Stroudism's Avatar
Got Boost?
TX Boosted 8 Running too Rich (w/ AP)
My 8 is turbo-charged and the shop that did the tuning went bananas on the rich side as I mentioned it is my Daily Driver. It idles at about 12-12.5 AFR. How can I lean this out? It seems that it's running in Open Loop. What tables to I modify in the AccessTuner? I tried changing the Closed-Loop Target A Table at .13 and .15 Load from .94 to .98 and .96 to .98 (respectively). This did not seem to help. The exit for the Target A and B is set to .99 from 1000 - 4000 rpms which seems correct. Any advice or help is much appreciated.
BTW - I am getting about 12-13 mpg in this beast, lol.
Old Apr 7, 2011 | 11:13 AM
jtripp06's Avatar
subscribing to this.
Old Apr 7, 2011 | 02:44 PM
Brettus's Avatar
Boosted Kiwi
you should have a stock map to compare to
check and put back to stock all settings below 30% load and 1000rpm in these tables:
Main fueling table
C/L Target A
C/L Target B
C/L exit load A , B & C
C/L exit throttle
C/L exit rpm
Also check your fuel trims at idle - a large +ve trim could indicate a vac leak
Old Apr 7, 2011 | 03:39 PM
Stroudism's Avatar
Got Boost?
Main fueling table
C/L Target A
C/L Target B
C/L exit throttle
C/L exit rpm
Brettus, I was actually just thinking about that, but you saved me time by narrowing the tables for me. Thank you. Excuse my ignorance, but what does "+ve trim" mean?
My boost gauge shows about 22-25 mmHg at idle. This is normal, right?
Old Apr 8, 2011 | 02:54 AM
Brettus's Avatar
Boosted Kiwi
LTFT long term fuel trim
lot higher than what i see (16-17) where is your boost gauge hooked up ?
Old Apr 11, 2011 | 08:24 AM
Stroudism's Avatar
Got Boost?
I checked the LTFT while I was driving and it said 0% the whole time. I guess I remembered wrong: I am actually geting 18-20 mmHg at idle. I am not sure exactly where the boost gauge is hooked up, I forgot to check over the weekend.
Old Apr 11, 2011 | 02:14 PM
arghx7's Avatar
18-20 millimeters of mercury? or inches?
Old Apr 12, 2011 | 09:37 AM
Stroudism's Avatar
Got Boost?
millimeters
Old Apr 12, 2011 | 11:54 AM
arghx7's Avatar
millimeters
Are you SURE?
because that means you have a MASSIVE vacuum leak, something is up with your gauge, or some other significant problem. Engine vacuum does vary but anything less than 400 mm Hg (about 16 inches) would indicate to me problem, unless you have porting.
Old Apr 12, 2011 | 12:05 PM
NgoRX8's Avatar
lol!
The normal reference for engine vacuum is inHg in this case.
Are you getting a reading for STFT at idle? If it's zero then you are in open loop so you'll need to mess with your closed loop exit tables.
Old Apr 12, 2011 | 02:14 PM
Stroudism's Avatar
Got Boost?
Are you SURE?
I will double-check tonight, but I thought it was mmHg.
Old Apr 12, 2011 | 02:17 PM
Stroudism's Avatar
Got Boost?
Originally Posted by NgoRX8
lol!
I checked the STFT at idle over the weekend, but I can't remember what it was. I think it was actually negative. I'll run it again tonight or tomorrow and report back. I'm almost positive that I'm running in open loop and I have been screwing with the closed loop exit tables to match or get close to the stock values. It has helped, but I'm still running rich at idle. I'm tempted to post my map so somebody can give some insight. Which tables are the open-loop tables?
Old Apr 12, 2011 | 04:02 PM
NgoRX8's Avatar
If you are seeing negative values on the stft, you are still in closed loop. Also why your closed loop tables are affecting it. What numbers are in the closed loop a/f target tables for your idle and your a/f target table
Old Apr 12, 2011 | 05:15 PM
Why don't you just log and post it up here for all to see? That would probably help.
Old Apr 13, 2011 | 09:42 AM
Stroudism's Avatar
Got Boost?
Are you SURE?
I'm dumb, it was InHg, you are right.
Old Apr 13, 2011 | 09:57 AM
Stroudism's Avatar
Got Boost?
Here's my data log from this morning. You will see one point where I turned the air on and it ran really lean for a second before I turned in off (load goes up too). I'm not sure why the car has idling issues when the air is on since I added a grounding kit and new battery...
STFT is about -20% at idle... I don't know why I'm running in open loop, but my lambda is 1.0 for all values where RPM is 500-1500
File Type: zip
Old Apr 13, 2011 | 12:40 PM
NgoRX8's Avatar
you aren't running in open loop. you are in closed loop because you have a value in your STFT. with that -20 STFT at idle you can see the ecu is trying to take out a lot of fuel.
so your values in your Air/Fuel Gear tables for idle are lambda of 1.0? What about Closed Loop A/F Target A & B tables?
Old Apr 13, 2011 | 01:36 PM
arghx7's Avatar
MAF or injector settings/scaling
Old Apr 13, 2011 | 01:44 PM
MazdaManiac's Avatar
There is a LOT of incorrect information and thinking in this thread. I'll get to it a bit later.
Old Apr 13, 2011 | 03:19 PM
Stroudism's Avatar
Got Boost?
They are also around lambda of 1.0, but I will have to double check that tonight when I get home. I basically copied stock values for those tables except for where load or RPMs were out of idle range.
Old Apr 13, 2011 | 03:20 PM
Stroudism's Avatar
Got Boost?
I was wondering about this as well. I know the tuner changed the scaling, but again I need to look at these values, because in the middle of the range, the values matched the stock ones. The new MAF housing is 3" where I believe the stock was 2.88"? This sound right?
Old Apr 13, 2011 | 03:41 PM
NgoRX8's Avatar
Umm... Stock MAF housing is 3.375 inner diameter.
Old Apr 13, 2011 | 05:39 PM
Stroudism's Avatar
Got Boost?
Oh ****, that's right. Kit came with a 3" pipe, shop had to cut and install at 3.5" pipe which is slightly larger.
Old Apr 14, 2011 | 12:03 AM
Brettus's Avatar
Boosted Kiwi
/\ problem solved . Get the right sized tube in there and go back to stock settings for MAF calibration and start the tuning over .
Old Apr 14, 2011 | 12:10 AM
Who setup and tuned your car man?
