Fuel Economy Charts
Old Feb 19, 2004 | 11:03 PM
timbo's Avatar
rock-->o<--hard place
Fuel Economy Charts
I have put together a variety of charts tracking consumption trends over 22,000k. I am not sure they prove much, other than that the RX-8, in common with most cars, loosens up over time and thus becomes marginally more fuel efficient. :p
As to something happening with the ECU at 20K - well, draw your own conclusions.
I shall continue to collect the data and post from time to time.
Tim
First, fuel consumption calculated at each fill (bottom axis is the odometer reading)
Old Feb 19, 2004 | 11:05 PM
timbo's Avatar
Next, the long run average fuel consumption (ie, progressive litres used against progressive k's travelled)
Old Feb 19, 2004 | 11:06 PM
timbo's Avatar
Finally, the average fuel consumption calculated in 2,000K stages
Old Feb 19, 2004 | 11:07 PM
timbo's Avatar
Lies, damned lies … and statistics
Old Feb 20, 2004 | 12:06 AM
rpm_pwr's Avatar
So according to the graph, if you put another 600,000km's on the car, it will actually start making fuel?
Old Feb 20, 2004 | 12:34 AM
timbo's Avatar
Yep -- I reckon it'll make that little Prius look like a gas guzzler
Old Feb 20, 2004 | 12:40 AM
RXE16T's Avatar
'RX-EIGHT'
I hope you're right about the fuel economy improving Timbo, because my 8 is a gas-guzzler at the moment!
Old Feb 20, 2004 | 12:48 AM
Gomez's Avatar
Shifty Bastard.
So none of you blokes have ever driven a 440ci Six Pack (3 Holleys) Dodge then....:D
Gomez
Old Feb 20, 2004 | 12:54 AM
timbo's Avatar
Gomez
No … but I have had a 4.6L Range Rover, which was fun to drive … from petrol station to petrol station…!
Old Feb 20, 2004 | 01:50 AM
jax8's Avatar
I had a de Tomaso Longchamp whose greed was in the RR category.
The hairline fractures it developped in suspension and chassis after 12 months on country roads was scary.
Old Feb 20, 2004 | 05:36 AM
Hymee's Avatar
Race Steward
Timbo,
Very well Done!!
You get Hymee's Most Informative Post Of the Week Award!
Congratulations! As a special reward, you get to increase you post count by 1 every time you reply to this, and pat yourself on the back.
Cheers,
Hymee.
Old Feb 20, 2004 | 05:50 AM
takahashi's Avatar
i did a try run in the freeway today (to work) and I have 10.8L/100km
I am only up to 5600km @ the odo so plenty of time to loose up the engine.
Old Feb 20, 2004 | 07:21 PM
timbo's Avatar
Originally posted by Hymee
[B]Timbo,
Very well Done!!
Aw shucks, thanks Hymee
Actually, I don't know that it was all that informative. Certainly not as I thought might be the case, given my sense that I had a reasonably steady-state driving pattern. Apart from an obvious long run (but small) decline in f/c (expected), it shows again that chaos theory can and will interfere in most 'real world' tests.
I'd still like to get to the bottom of all these ECU features and myths.
Woo hoo -- look at that, I posted this and my post count increased by… by… one! :p
Old Feb 21, 2004 | 12:26 AM
Hymee's Avatar
Race Steward
So here is a chance to up your post count, yet again
Is the trend line on the first graph calc'd by Excel, or did you eyeball it?
My impression is that if there was a "magic switch" you would see the change happen more noticably at that point in time. But a trend line, depending on the smoothing, can hide a deviation like that.
Cheers,
Hymee.
Old Feb 21, 2004 | 03:15 AM
timbo's Avatar
Calculated by Excel. 2nd order polynomial, as I read the fn description. It would hide the switch, as you say. That's why I then calculated averages in blocks of 2,000Ks. While that showed a switch, there were also previous ones. Result: inconclusive
Old Feb 21, 2004 | 04:00 AM
Hymee's Avatar
Race Steward
That was a good reply - worthy of the additional post count
I think it would appear to be a long term trend, rather than a binary (on/off) sort of thing.
Cheers,
Hymee.
Old Feb 21, 2004 | 11:51 AM
Gomez's Avatar
Shifty Bastard.
I got the impression from the Renesis Tech that the mixture started leaning off around 20K...IE, no switch.
Will grill him further when I pick up the car...
Gomez
Old Feb 21, 2004 | 06:00 PM
Wildcard's Avatar
NT Rotorhead
We can't wait to hear what he has to say! There has been rumour and speculation ever since the '8 came out about the ECU being programmed to give more power after a certain number of km's. It would be great to get some hard facts.
Old Feb 21, 2004 | 06:21 PM
Hymee's Avatar
Race Steward
I hope it isn't the same tech who said the noise at startup was the ceramic seals
Old Feb 21, 2004 | 06:45 PM
Wildcard's Avatar
NT Rotorhead
True.... While Mazda Japan clearly know this car backwards (because they built it), Mazda Australia seem to know f*ck all. At least that's been my personal experience. I have much more faith in the collective knowledge of this forum than I do in the Mazda Aust. tech-hotline.
Old Feb 21, 2004 | 07:25 PM
Hymee's Avatar
Race Steward
Agreed wholeheartedly!
But I bet if ya were on the 'phone to the tech-hotline and said "I was reading on the Internet Forum about such and such...." they would laugh and think you were an idiot
(Although I would hope not!)
Cheers,
Hymee.
Old Feb 22, 2004 | 06:05 PM
skc's Avatar
skc
rev it up
great stats Timbo. I look forward to more economical driving as the car runs in.
Old Feb 22, 2004 | 06:43 PM
timbo's Avatar
Better get driving tips from labrat
Old Feb 26, 2004 | 08:02 PM
RichardM's Avatar
I'm surprised by the figures.
I’d have thought that the RX8 would have averaged a lower consumption figure than that? Somewhere in the mid 11s.
My average fuel consumption is 12.86 L/100km with a 5.7Litre motor (and 7.31L/100km from my 323).
Is this the fuel problem that was touched on in another thread?
Old Feb 26, 2004 | 08:56 PM
timbo's Avatar
I guess it all has to do with the higher RPM of the rotary, and the rich fuel/air mix used, especially once the revs top 3,250. Hymee and others have more knowledge on all this and there are some fuel/air mix charts as part of dyno runs elsewhere on the forum.
But I understand the Renesis is still somewhat more economical than earlier rotaries.
In the meantime, GM has been working hard to increase the efficiency of its bent engines: the wife's Calais (pov 3.8 V6 non s/c model) manages below 10L/100K in mixed driving -- better than my previous V6 Astina!!
