Water Marks Removal
Old Feb 28, 2011 | 08:18 PM
YKRABOI's Avatar
flavoredtoothpaste
Water Marks Removal
Greetings all,
I'm on a verge of going crazy because I can't get rid of watermarks that accumulated on the right hand side of my car. I have tried NuFinish scratch remover but it didn't work. Do any one of you know a compound that I can buy to get rid of this problem. Also, the window on my suicide door has some spots. I hate neighbor sprinklers. Thanks
Old Feb 28, 2011 | 08:48 PM
laythor's Avatar
I zoom therefore I am.
shower cleaner
Old Feb 28, 2011 | 09:09 PM
Grace_Excel's Avatar
Charles Bundy
You gotta wax and clay-bar it, it's hard work but it will work.
Old Mar 1, 2011 | 12:43 AM
Twiztog43's Avatar
not worth all the work if its going to rain again in a couple days!
Old Mar 1, 2011 | 01:13 AM
Charles Bundy
"Prevention through early detection and treatment..."
Old Mar 1, 2011 | 01:57 AM
Twiztog43's Avatar
Originally Posted by YKRABOI
Greetings all,
my friend has that on his car too. his neighbor uses some kind of additive to help the grass. we couldnt get it off with rubbing compound. havent tried clay bar though.
Old Mar 1, 2011 | 04:11 AM
YKRABOI's Avatar
flavoredtoothpaste
has anyone heard of the vinegar and water mixture solution?
Old Mar 1, 2011 | 01:50 PM
Charles Bundy
You could try it but use distilled water instead of tap water.
Old Mar 1, 2011 | 02:03 PM
laythor's Avatar
use shower cleaner, it already has distilled water in it. when i bought my car in 07 it had been sitting on the dealer lot for 8 months. water spots were on everything. Cleaning and claybar did little, but a good spritzing of shower cleaner and a micro fiber cloth doing it a couple of times letting the cleaner sit for awhile between rub downs took car of everything. Make sure to rinse the car thoroughly then wash, and wax afterward.
Old Mar 22, 2011 | 07:04 AM
DeKaB21's Avatar
SpoolinRx8
What type of shower cleaner like a brand name or some? Plz thanks
Old Mar 22, 2011 | 11:16 AM
laythor's Avatar
i used the target house brand simply because we had some in the house. Just look for "daily shower cleaner", not the super duper, once every year, wear gloves and full body armor spray.
Old Mar 26, 2011 | 02:23 PM
bse50's Avatar
#50
warm water and vinegar ftw
Old Apr 5, 2011 | 09:44 PM
ganseg's Avatar
Nature vs. Nurture
Originally Posted by laythor
use shower cleaner, it already has distilled water in it. ...a good spritzing of shower cleaner and a micro fiber cloth doing it a couple of times letting the cleaner sit for awhile between rub downs took car of everything. Make sure to rinse the car thoroughly then wash, and wax afterward.
Is it called Up and Up in a clear bottle with a very light green sprayer? it doesn't say the active ingredient, but it must not be too strong.
Old Apr 6, 2011 | 08:35 AM
laythor's Avatar
that would be the one.
Old Apr 6, 2011 | 08:40 AM
ganseg's Avatar
Nature vs. Nurture
This is a very novel approach! Do you think I could go one step stronger? My spots were too tough for it. (yes, I did both soak and rub with microfiber)
Old Apr 6, 2011 | 08:59 AM
ZOOM-I-DO's Avatar
This explains what to do in detail. Hope it helps.
http://meguiarsonline.com/forums/showthread.php?t=14860
Old Apr 26, 2011 | 01:43 AM
Ernie B's Avatar
your going to have to get a buffer and take a heavy duty wool pad with some 1500compound.. they'll come right out. (im a professional detailer)
Old Apr 26, 2011 | 01:44 AM
Ernie B's Avatar
and as far as the spots on the windows use a triple zero (000) grade steel wool pad make sure its dry
Old Dec 1, 2011 | 11:55 PM
yushinrt's Avatar
picture will be great use mag acid watered down mag acid, i use it all the item you just have to watch out with this method
1.wash your car like normal
2 spray mag acid stright or watered down (at your own risk)
3.brush the mag acid on to the body panel (try not to get it on plastic and window)
4.wait few minutes then water it down make sure you wash off the acid from your car
( i recommended to wash the car)
5.the water spots should be gone if it still there dont water down the mag acid or leave the acid for bit longer
Racingjunkie
Sep 29, 2015 05:05 PM
XianUnix
Sep 29, 2015 03:48 PM
DG07
Sep 28, 2015 10:58 AM
Learners_Permit
Sep 27, 2015 07:38 PM
