Aluminum Gas Pedal Upgrade
Old Feb 26, 2011 | 08:01 PM
Tonicart's Avatar
(Dustin)
I was looking at the part on Mazdatrix but wondering how difficult is it to install? Not sure if these are just a plug-in electrical switch or more complicated... Anyone have an install guide?
http://www.mazdatrix.com/8interior1.htm
TIA!
Old Feb 26, 2011 | 10:24 PM
canaryrx8's Avatar
it's the easiest thing in the world, straight swap. The brake pedal is trickier getting the pad to fit etc. but the gas pedal is mega easy.
Old Feb 27, 2011 | 12:31 AM
Tonicart's Avatar
(Dustin)
Ah, sorry, thought the MT might be diff from the AT... just wanted to make sure... wonder if Mazdatrix ships the parts with instructions? I want to replace the whole set down there, lol. Dead pedal, brake pedal pad, and gas
Thanks.
Old Feb 27, 2011 | 02:30 AM
monchie's Avatar
I HATE SPEEDBUMPS!
Pics after install...
Old Feb 27, 2011 | 10:16 AM
canaryrx8's Avatar
Thanks.
the oem mazda ones come with full instructions, I swapped gas/brake on mine, the brake pedal was a pad that replaces the rubber pad on the factory pedal, clutch is probably done the same way on the Mt's. My dead pedal got replaced with a speaker pod, it was pretty easy to take out so my guess is the factory piece probably just replaces that as well.
Old Feb 28, 2011 | 05:28 AM
slvrstreak's Avatar
Angler of the Year
i have the aluminum pedals for sell if you're interested
Old Mar 4, 2011 | 09:14 AM
Tonicart's Avatar
(Dustin)
Ah, bought them already. Arrived yesterday, all three pedals came with OEM instructions, sweet. Got clear corners too, no instructions but those are easy to do.
I'll try to do a DIY guide while I do it this weekend, weather permitting
Old Mar 4, 2011 | 09:28 AM
slvrstreak's Avatar
Angler of the Year
please do
i bought the aluminum pedals off a totaled rx-8...dead pedal and accelerator i can swap easily but the brake pedal is a different size
gonna have to figure something out there :/
Old Mar 5, 2011 | 12:57 AM
Tonicart's Avatar
(Dustin)
Is yours an AT or MT?
Old Mar 5, 2011 | 06:32 PM
slvrstreak's Avatar
Angler of the Year
AT thats why the manual brake pedal wont fit :/
Old Mar 6, 2011 | 11:32 AM
EDZRIDE's Avatar
2005 White GT
Tonicart, use a little liquid soap to install the brake pedal pad.
Old Mar 7, 2011 | 05:25 AM
slvrstreak's Avatar
Angler of the Year
no its a completely different size...AT brake pedal is about twice as big
probably going to cut the AT pedal off and weld the manual on or maybe make my own aluminum piece to go over the AT pedal???
ill post a pic when i get home
Old Mar 8, 2011 | 11:01 AM
Tonicart's Avatar
(Dustin)
OK, so all three pedals came with "technical" Mazda install instructions. Great, if you have little magical gnomes that can fit in there and turn the little nuts.
I got the dead pedal on, easy. Gave up on the brake pedal pad. Gonna try the soap, thanks. The accel. pedal, omg, how do you get that top nut off? I got the socket wrench on there, but goddamn it's hard to torque and see what you're doing.
The mazda dead and accel. pedals are basically the stock stuff with an aluminum plate/sheet attached to the top. Couldn't they just sell that alum. piece? lol... wish I had looked for better photos of the parts before I bought them. Tempted to just remove the alum. part of the accel. pedal and glue it onto the stock pedal!
Old Mar 8, 2011 | 12:29 PM
EDZRIDE's Avatar
2005 White GT
U-joint & extension worked for me.
Not a good idea! If you can't get the accelerator assembly installed, take it to a shop, shouldn't cost more than .5 hours labor charge.
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
XianUnix
Sep 29, 2015 03:48 PM
drlubell
Sep 26, 2015 11:58 PM
